- Model Requests
- Request for Devo8 Models for any 450 helicopter
- Fernando
13 Jul 2016 08:44 #51599
by Fernando
Request for Devo8 Models for any 450 helicopter was created by Fernando
Hi everyone,
Just for testing purposes and to be sure the models I make by myself are well configured, I ask for a 450 model.ini file.
I really need it because I find some issues while flying and I think there is something wrong on my configs. Just if it were important, my 450 is a Tarot Pro and I fly with a Vbar FBL.
Please, I just want to load the model on my Devo and check its parameters with my own. It will be really helpful.
Thank you for your help.
Regards.
Regards.
- -=Hubi-Dirk=-
13 Jul 2016 16:14 #51604
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Request for Devo8 Models for any 450 helicopter
Ok, which RX?
- Fernando
13 Jul 2016 17:38 - 13 Jul 2016 17:39 #51615
by Fernando
Replied by Fernando on topic Request for Devo8 Models for any 450 helicopter
My RX is a Spektrum Satellite. I bind with a DSM2 receiver.
Last edit: 13 Jul 2016 17:39 by Fernando.
- -=Hubi-Dirk=-
13 Jul 2016 19:17 #51618
by -=Hubi-Dirk=-
Try the attached .ini as an example.
1. THR 1:1 for spinning up, FMODE 1 & 2 = Fixed for Governor Mode
2. AIL & ELEV: Less DR and more EXPO swiched by AIL and ELV DR Switches
3 RUD = Simple 1:1
4. Ch6 as Pitch: Flat curve fpr spinning up, FMODE 1 & 2 = Full pos and neg Pitch
3 RUD = Simple 1:1
- -=Hubi-Dirk=-
13 Jul 2016 19:24 - 13 Jul 2016 19:40 #51619
by -=Hubi-Dirk=-
If you dont use Governor at Throttle, the attached .ini has differnt V-Curves at FMODE 1 & 2
Last edit: 13 Jul 2016 19:40 by -=Hubi-Dirk=-.
- Fernando
14 Jul 2016 06:42 #51631
by Fernando
Thank you -=Hubi-Dirk=-, I will test it and will post the results. I do not fly with governor but I were thinking to enable it soon, so very useful as well.
- Fernando
31 Jul 2016 15:17 #52322
by Fernando
Hi!, I loaded at last.
I have seen your config and see that your GEAR channel (5) you have NONE. How do you set the tail gain?
I use the switch GEAR to switch between head lock (around 40, variable) to avoid fishtail, and -100 to unset the heading lock.
-=Hubi-Dirk=- wrote: If you dont use Governor at Throttle, the attached .ini has differnt V-Curves at FMODE 1 & 2
- Model Requests
Time to create page: 0.111 seconds
Model Configs
Model Requests
