JJRC H26D
11 Jan 2016 20:10 #41644 by SeByDocKy
JJRC H26D was created by SeByDocKy
Here are the SPI capture for the new JJRC H26D.
mon-partage.fr/f/7ynIDjiO/
- Controls are taken in expert/100% mode
This quad have:
-Headless
-RTH
-Flips
-Photo
-Camera
-2-axis gimbal control (pan & tilt)
12 Jan 2016 01:37 #41652 by hexfet
Replied by hexfet on topic JJRC H26D
Please try binding with MJXQ protocol WLH08 option. Bind address and packet size is the same. Let's see how far that gets us before digging in deeper.
12 Jan 2016 08:27 #41661 by SeByDocKy
Replied by SeByDocKy on topic JJRC H26D
hexfet wrote: Please try binding with MJXQ protocol WLH08 option. Bind address and packet size is the same. Let's see how far that gets us before digging in deeper.
Well I tried first all XN297 protocols ... and even the MJXq/WLH08 is not working :( (no binding)
12 Jan 2016 16:37 #41677 by hexfet
The RF channels are different :dry:
I've uploaded at test build titled H26D. It has a protocol option under MJXQ. Please give that a try. Unfortunately this build no longer fits in the 7e...
12 Jan 2016 18:14 #41679 by SeByDocKy
hexfet wrote: The RF channels are different :dry:
Harg I got only my Devo 7E on hands actually ....
12 Jan 2016 18:35 #41682 by SeByDocKy
Ok I found my Devo10 ... but it doesn't bind :(
12 Jan 2016 19:01 #41684 by hexfet
I'll have to look in greater detail. Might take a few days.
12 Jan 2016 19:16 #41686 by SeByDocKy
hexfet wrote: I'll have to look in greater detail. Might take a few days.
No problem :) ... I can capture anything you need in case
12 Jan 2016 21:20 #41692 by hexfet
One more quick try. I updated the test build to force the txid to the same value in your capture.
It would be helpful if you could export the existing captures to csv :)
12 Jan 2016 21:51 #41694 by SeByDocKy
hexfet wrote: One more quick try. I updated the test build to force the txid to the same value in your capture.
Not working too :(
12 Jan 2016 23:38 #41696 by hexfet
Missed the forest for the trees :oops: It's a Beken chip, not XN297. Test build is updated.
13 Jan 2016 08:08 #41707 by SeByDocKy
hexfet wrote: Missed the forest for the trees :oops: It's a Beken chip, not XN297. Test build is updated.
Now it's binding :) ... Ok I will check all associated channels now
13 Jan 2016 11:21 #41708 by SeByDocKy
Ok ... so what I managed to test
Lights ok
Flips probably yes (I can't test too windy))
photo ok
camera ok
Headless ok
Can the gimbal controls be added to last channels ?
headless ok
13 Jan 2016 13:49 #41713 by hexfet
The pan/tilt is implemented with a series of bit transitions. Need a little time to figure out the best implementation.
How about RTH? It looks like there's a capture for an altitude hold function too. We're about out of channels.
13 Jan 2016 16:50 #41718 by SeByDocKy
hexfet wrote: The pan/tilt is implemented with a series of bit transitions. Need a little time to figure out the best implementation.
I will make some deeper testing.
Can you list me associated channel number with corresponding features ? to be sure ?
For your combo ... maybe it's time to give up some very unpopular protools ? (CFLY ?)
13 Jan 2016 23:25 - 13 Jan 2016 23:31 #41735 by hexfet
I've implemented the pan/tilt controls. Took a stab at making them proportional but don't know if the quad will respond appropriately. A channel value of 50 should give about the same gimbal rate as stock. At the low end should be twice as slow. At the high end the bits toggle every packet - no telling if the gimbal will keep up. If it works at all please judge the desirability of proportional control - it's messy and requires a good bit of code.
I also changed the txid code to add the fixed id to your stock tx value. Setting the fixed id to zero will give same txid as the previous version. Please try with a non-zero value and see if it binds. If it doesn't we've got the txid<-->rf channel mapping to figure out.
Here's the channel assignments. If the H26D does not have LED control we could use channel 5 for altitude hold.
#define CHANNEL_LED         CHANNEL5
#define CHANNEL_FLIP        CHANNEL6
#define CHANNEL_PICTURE     CHANNEL7
#define CHANNEL_VIDEO       CHANNEL8
#define CHANNEL_HEADLESS    CHANNEL9
#define CHANNEL_RTH         CHANNEL10
#define CHANNEL_AUTOFLIP    CHANNEL11  // X800, X600
#define CHANNEL_PAN         CHANNEL11  // H26D
#define CHANNEL_TILT        CHANNEL12
Last edit: 13 Jan 2016 23:31 by hexfet.
14 Jan 2016 08:40 - 14 Jan 2016 08:54 #41743 by SeByDocKy
hexfet wrote: I've implemented the pan/tilt controls. Took a stab at making them proportional but don't know if the quad will respond appropriately. A channel value of 50 should give about the same gimbal rate as stock. At the low end should be twice as slow. At the high end the bits toggle every packet - no telling if the gimbal will keep up. If it works at all please judge the desirability of proportional control - it's messy and requires a good bit of code.
Some good news: Gimbal controls works (I associated them with AUX4&5)
Even if the light controls is not present with the original radio, it's working here ... so basically we would need 13 channels !!! to add the the "pseudo altitude hold/height" for the 13th ...
I bound with ID = 1111 w/o problem
Last edit: 14 Jan 2016 08:54 by SeByDocKy.
14 Jan 2016 13:39 #41748 by hexfet
That is good news :) Does the speed of the gimbal increase with larger channel values? If so, at what value does it reach maximum speed?
We could add a protocol option to swap functions of one of the channels. Probably exchange either LED or flip control with altitude hold.
Also good news on the ID. Thanks for testing!
14 Jan 2016 14:20 #41751 by SeByDocKy
hexfet wrote: That is good news :) Does the speed of the gimbal increase with larger channel values? If so, at what value does it reach maximum speed?
Well ... to be honest, there is a small variation is speed around the central pot values. In practice, you have to be very precise to "stop" spinning... so probably the dynamic should be adapted when used with pots..... I should try with some trim buttons too... it can be a different storry.
What's a pity the HexFet devo7E combo is full for this protocol :( .... I was planning to use my Devo7E... Definitively, we are reaching the memory limits now.
We should do Force walkera to deliver 7E with a 256Ko chip :)
Out of topic... I will also capture the JJRC X1 spi data asap
14 Jan 2016 17:49 #41755 by hexfet
There's no info in the altitude hold or flip captures - just the bind sequence followed by unchanging data. Need to get the altitude hold info.
I've updated the test build with the following changes. Please check and let me know.
The gimbal code is changed to just use the fixed rate same as the stock tx. If the channel is outside +/-50 the gimbal will move, otherwise it will not. See if this is easier to work with than the previous version.
The txid code is changed to same as the x800 (basically ignored). Should still work.
I was able to build a 7e version with gcc 4.8.4 :) Cannot build the 7e with 4.9.3 due to space.
Time to create page: 0.158 seconds
