Yi Zhan i6S capture
22 Jan 2016 13:06 #42071 by SeByDocKy
Yi Zhan i6S capture was created by SeByDocKy
Here are some SPI captures of this really nice sporty nanohexcopter (XN297 based)
mon-partage.fr/f/9kyTFKq3/
Be aware, mine is a little bit deffective and I have some to turn on/off serveral time the radio to bind the quad. So in capture, I should have 2 or 3 files with a working binding process. I think it should be ok...
22 Jan 2016 15:20 - 22 Jan 2016 15:24 #42077 by goebish
Replied by goebish on topic Yi Zhan i6S capture
I might have a look later.
Meanwhile, if anyone else wants to try to implement it, you'll need this patch which has not been pushed to default yet, or 9 byte payload with CRC enabled won't work:
bitbucket.org/goebish/deviationtx/commit...cdce401bc?at=default
(oops ;))
Last edit: 22 Jan 2016 15:24 by goebish.
22 Jan 2016 15:31 - 22 Jan 2016 15:36 #42078 by goebish
A first glance it looks pretty similar to the H7 / MT99xx protocol, I think a protocol format option should be fine, I could take this opportunity to finally fix the H7 protocol since the changes I made for MT99xx seem to have broken a few things hence this protocol has not been pushed to default yet.
Last edit: 22 Jan 2016 15:36 by goebish.
22 Jan 2016 15:42 #42080 by SeByDocKy
Replied by SeByDocKy on topic Yi Zhan i6S capture
goebish wrote: A first glance it looks pretty similar to the H7 / MT99xx protocol, I think a protocol format option should be fine, I could take this opportunity to finally fix the H7 protocol since the changes I made for MT99xx seem to have broken a few things hence this protocol has not been pushed to default yet.
Ho great :)
27 Jan 2016 19:47 #42283 by SeByDocKy
Any news ? :)
27 Jan 2016 20:01 #42285 by goebish
it's on my todo list for next week-end ;)
27 Jan 2016 20:09 #42287 by SeByDocKy
goebish wrote: it's on my todo list for next week-end ;)
Ok :) be aware, I can fill your todo list with new protocols :)
- JJRC H29G
- Cheerson CX-35 (no more using the CX-10 green like the CX-32/CX-33 :()
- Fayee FY805 (a picohexa)
-JXD 809 (in fact it's the Q282 protocol but need to capture the "start engine" button)
- DWI DF32
28 Jan 2016 12:59 - 28 Jan 2016 13:00 #42313 by goebish
I had a further look at the i6S capture, looks like it's using the new XN297L ?
If that's the case it operates @ 250kbps :)
17 W_REGISTER(RF_SETUP) FF
... I just declined the pull request for my MT99xx branch, I'll make a new proper one and create a new PR once this new format is ready...
Last edit: 28 Jan 2016 13:00 by goebish.
28 Jan 2016 13:09 - 28 Jan 2016 13:10 #42314 by SeByDocKy
goebish wrote: I had a further look at the i6S capture, looks like it's using the new XN297L ?
Bingo :)
File Attachment:
I understand why the control range is improved versus Basic toys XN297 based
Last edit: 28 Jan 2016 13:10 by SeByDocKy.
28 Jan 2016 13:11 #42315 by goebish
Ok, I've to understand how channel hopping works, shouldn't be very difficult but it's not exactly the same than H7 / MT9916.
28 Jan 2016 13:20 - 28 Jan 2016 13:47 #42316 by goebish
SeByDocKy wrote: I understand why the control range is improved versus Basic toys XN297 based
From what I understand to the datasheet (mix of Chinglish ...) the XN297L has an integrated +13dBm PA ... but well, the non "L" version has +10dBm still it was not better than nrf24l01+ with no external PA (0dBm).
Last edit: 28 Jan 2016 13:47 by goebish.
28 Jan 2016 14:03 #42318 by SeByDocKy
yes and add also that the RX sensitvity @250kbit should probably +6dBm better than at 1mbits so +3dBm for the TX part, probably + 6dBm sp range x2.5
28 Jan 2016 14:44 #42322 by goebish
Note to my future self: always 'make distclean' after switching branches.... I've been struggling more than one hour wondering why MT99XX and MJQx didn't appear in my build :whistle:
28 Jan 2016 14:50 #42323 by SeByDocKy
goebish wrote: Note to my future self: always 'make distclean' after switching branches.... I've been struggling more than one hour wondering why MT99XX and MJQx didn't appear in my build :whistle:
can you start from the last HexFet combo build ? :) got almost everything there :)
28 Jan 2016 15:18 - 28 Jan 2016 15:20 #42325 by goebish
No, I've to start from default or this will be a mess to merge afterward ;)
Last edit: 28 Jan 2016 15:20 by goebish.
28 Jan 2016 17:13 #42327 by hexfet
Replied by hexfet on topic Yi Zhan i6S capture
Everything's been merged to default. Nothing special in the combo build at the moment.
28 Jan 2016 18:49 #42331 by goebish
How do you arm ?
I can't find the manual ...
28 Jan 2016 18:54 #42332 by SeByDocKy
goebish wrote: How do you arm ?
throttle up & down .. be aware, i have only few captures of the arming sequence coz my Yi-Zhan I6s is a bit buggy for this step
28 Jan 2016 19:04 #42333 by goebish
Ah ok I think I understand ...
Regarding your issue I suppose your stock TX needs sticks recalibration, but I've no idea if you can even do that ...
28 Jan 2016 19:14 #42334 by SeByDocKy
goebish wrote: Ah ok I think I understand ...
No in fact, sometimes the binding is failing .... so no possibility to arm
Time to create page: 0.226 seconds
