Yi Zhan i6S capture
03 Feb 2016 16:23 #42546 by SeByDocKy
Replied by SeByDocKy on topic Yi Zhan i6S capture
goebish wrote: Hmmm probably a stupid question, but are you sure the module you have in your 7e can do 250Kbps ?
I tested unscrambled mode + crc with 9 byte payload on my test xn297 RX (but at 1Mbps...) and it's working fine, when I start my Devo10 with i6S protocol selected (but hacked for 1MBps...) my "rx" receives the bind packets.
Yes it's the same module for both my Devo10 & 7E. I will test the Devo10 build
03 Feb 2016 16:29 #42547 by SeByDocKy
Not working too with the devo10 (last build was working)
03 Feb 2016 17:23 #42548 by goebish
Replied by goebish on topic Yi Zhan i6S capture
That's weird, I'm sure my algo returns the same result than with using a table, or my XN297 RX wouldn't receive anything with CRC enabled ...
Can you check if other xn297 protocols are working with this version please ?
03 Feb 2016 17:25 #42549 by goebish
Lol, I feel dumb, my H7 doesn't bind anymore either with this version ...
I'll check what's wrong.
03 Feb 2016 18:12 - 03 Feb 2016 18:14 #42552 by goebish
That's mind-blowing, I can see that the 2 versions send the same packets, with the same crc and all.... my test rx (an actual xn297) receives them, still the quads don't bind with the 2nd one...
Anyway, I was able to build the previous version for 7e as well, so it should be fine until I find what's wrong...
it has aileron/elevator swapped and rudder reversed.
Devo 7e
Devo 10
Last edit: 03 Feb 2016 18:14 by goebish.
03 Feb 2016 18:27 #42553 by SeByDocKy
goebish wrote: That's mind-blowing, I can see that the 2 versions send the same packets, with the same crc and all.... my test rx (an actual xn297) receives them, still the quads don't bind with the 2nd one...
Devo 7e
Devo 10
Ok binding fine now :)
AIL/ELE swap ok :) RUDDLER inverted ok :)
Please inverse also AIL & ELE ... ( I forgot that)
Actually no extra channels are working ...
03 Feb 2016 18:31 #42554 by goebish
Ok, extra channels are not implemented, I've to check the captures :)
04 Feb 2016 17:01 - 04 Feb 2016 17:04 #42574 by goebish
Version with extra channels, note that I couldn't find the flag in the "flip" capture, I suppose it requires a bit of throttle to work, can you make another capture for that ? (The quad doesn't need to be switched on, so you can capture at full throttle ;)).
CHANNEL5 LIGHT
CHANNEL6 FLIP (not working ...)
CHANNEL7 SNAPSHOT
CHANNEL8 VIDEO
CHANNEL9 HEADLESS
Devo 7e
Devo 10
Last edit: 04 Feb 2016 17:04 by goebish.
04 Feb 2016 18:18 #42578 by SeByDocKy
goebish wrote: Version with extra channels, note that I couldn't find the flag in the "flip" capture, I suppose it requires a bit of throttle to work, can you make another capture for that ? (The quad doesn't need to be switched on, so you can capture at full throttle ;)).
CHANNEL5 LIGHT
CHANNEL7 SNAPSHOT
CHANNEL8 VIDEO
CHANNEL9 HEADLESS
Devo 7e
Devo 10
Everything is working :)
I will recapture the flip channel :)
04 Feb 2016 18:31 #42579 by SeByDocKy
here is the flip button capture
mon-partage.fr/f/oz8bXWq9/
04 Feb 2016 22:16 #42593 by goebish
it should be complete now
Devo 7e
Devo 10
Do you have a chance to test the MT99xx sub format ?
04 Feb 2016 22:23 #42594 by SeByDocKy
goebish wrote: it should be complete now
Devo 7e
Devo 10
Work perfectly now .... :) can be pushed
I will try to test with my 9916 (if I can find it :)
05 Feb 2016 07:27 #42612 by SeByDocKy
Works fine with the MT99XX (at least flips, camera, & photo)
One general remark for the i6s & MT9XX. in general i use the throttle trim down to trigger camera recording. I am using the same config file with other protocols; Here, I need to keep hold down the trim button to continue the recording. There is a away to have a real latch D ?
05 Feb 2016 08:47 - 05 Feb 2016 08:48 #42618 by SeByDocKy
Demo flight
Last edit: 05 Feb 2016 08:48 by SeByDocKy.
05 Feb 2016 09:50 - 05 Feb 2016 09:51 #42622 by goebish
Thanks for testing :)
Sorry I cannot do what you want with trim button, but I think it can be done with the mixer settings no ?
(I admit I still have to read Deviation manual :blush:, after almost 3 years...)
Last edit: 05 Feb 2016 09:51 by goebish.
08 Feb 2016 14:03 #42770 by goebish
We forgot to check something: arbitrary tx id, my previous build has yours hardcoded, your values matched the known algo but better check before pushing as the protocol is not exactly the same.
Devo 7e
08 Feb 2016 14:40 #42771 by SeByDocKy
I will check that after my teaching
08 Feb 2016 14:42 #42772 by goebish
Oh you're a teacher ?
God I didn't like school :P
08 Feb 2016 17:43 - 08 Feb 2016 17:45 #42785 by SeByDocKy
With any fixed ID is no more binding ... :(
only empty one and ID = 2 are working now ... :(
Last edit: 08 Feb 2016 17:45 by SeByDocKy.
08 Feb 2016 17:46 - 08 Feb 2016 18:19 #42786 by goebish
Ok, so it's different... That doesn't surprise me much because it matched the algo, but it was a special case (channel offset from reference table = 0). I'll try something later but if it doesn't work I'll need a capture from at least one other i6S TX to understand how it works. (or a few captures from the RX, with some non working IDs, not easy as there's no test points to attach the probes to...)
Meanwhile, the code to be pushed has an hardcoded ID (just 1 byte), not a big deal unless 2 fliers want to use this protocol in the same area ;) it should be noted on the compatibility spreadsheet tho.
Last edit: 08 Feb 2016 18:19 by goebish.
Time to create page: 0.127 seconds
