LIANSHENG LS114 4CH 2.4GHz RTF UFO Drone SPI DATA
- 92zb
13 Apr 2016 16:04 #46431
by 92zb
LIANSHENG LS114 4CH 2.4GHz RTF UFO Drone SPI DATA was created by 92zb
You can download all the data for LS114 from here
www.mediafire.com/download/7429bqv4cv636...CKWORD-RIGHT-LEFT.7z
www.mediafire.com/download/ofs3qc5348872...ARD_BACKWORD_TRIM.7z
www.mediafire.com/download/upqgzk9pbgh97o9/RUDDER_TRIM.7z
www.mediafire.com/download/bb5yksm3ntg38...GHT_%26_LEFT_TRIM.7z
www.mediafire.com/download/w7zlj6p44l18b...-_HEADLESS-ON-OFF.7z
www.mediafire.com/download/229gnwcc6y4qi...E-EXPERT_MODE-OFF.7z
E&OE
E&OE
- goebish
- NRF Weirdo
13 Apr 2016 23:35 - 16 Apr 2016 23:00 #46454
by goebish
Replied by goebish on topic LIANSHENG LS114 4CH 2.4GHz RTF UFO Drone SPI DATA
I had a further look and as I thought this is similar to the MT99xx / H7 protocol except that it always transmits on the same channel.
I'll implement it and post a test firmware.
I also have to find why the optimized xn297 crc algo didn't work last time I had a look at it ... worst case I'll remove the i6S format option (the only one that's using xn297 unscrambled mode) for now.
Last edit: 16 Apr 2016 23:00 by goebish.
- goebish
- NRF Weirdo
16 Apr 2016 22:54 #46666
by goebish
I'll try to do it very soon™, sorry, so much stuffs to explore, so little time
- goebish
- NRF Weirdo
17 Apr 2016 23:47 #46725
by goebish
Here's a test build, select MT99XX protocol then LS114 format option:
Devo 7e: www.dropbox.com/s/j1gpx1wom6zmdwo/deviat...evo7e-ls114.zip?dl=0
Devo 10: www.dropbox.com/s/cafwolo7x0j1hdi/deviat...evo10-ls114.zip?dl=0
- 92zb
18 Apr 2016 04:57 #46730
by 92zb
Replied by 92zb on topic LIANSHENG LS114 4CH 2.4GHz RTF UFO Drone SPI DATA
Yes it works. A bit more sensative and a tendency to Yaw anti-clock wise. I have not tested in headless mode, or flips, cus I do not know the switch it requres.
I also have LS124 which is not head less, it also binded succesfully.
There is a file in your test build "debug-Devo7e-Unknown.zip", what is this for.
- goebish
- NRF Weirdo
18 Apr 2016 09:22 - 18 Apr 2016 11:27 #46733
by goebish
Cool
You don't need the zip that's inside the zip, it's only useful to developers.
Headless is not implemented because there was no trace of it in your capture (I think it doesn't trigger when throttle is low), I think you'll have to make another one.
For flips, try channel 6, it should work if it's using the same flag than MT99/H7, otherwise you'll have to make another capture.
Regarding Yaw, you had a lot of right trim on your stock transmitter, if you feel you can't set enough trim, go to the Trims screen then set 1.0 steps instead of default 0.1
Last edit: 18 Apr 2016 11:27 by goebish.
- 92zb
18 Apr 2016 14:23 #46740
by 92zb
Hi goebish, thank you very much for your help, I appreciate it very much and I am sure all those who have these q-copter.
I have captured some more, please have a look, if there is any more data you want, let me know.
www.mediafire.com/download/qh6gwgu8qxu91...ERT-HEADLESS-MODE.7z
www.mediafire.com/download/n2y3zj7pbojrnbo/RUDDER_LEFT_TRIM.7z
www.mediafire.com/download/npb8xopxq5t3y2a/RUDDER_RGHT-TRIM.7z
www.mediafire.com/download/f9ewhf1bd02rr...UP-DWN-RIGHT-LEFT.7z
www.mediafire.com/download/2vvici86shovfg6/HEADLESS_MODE.7z
www.mediafire.com/download/glaa6jm0ur5lgbj/EXPERT_MODE.7z
By the way what is this miss matching of data, should I be concerned and how can I avoid it in future capture.
Thanks for your help.
- goebish
- NRF Weirdo
18 Apr 2016 14:33 - 18 Apr 2016 14:42 #46741
by goebish
There's still nothing interesting in your "HEADLESS_MODE" capture, I think that's because throttle is down.
Give some throttle before capturing that (the copter doesn't need to be turned on ...)
You're having mismatch / errors because your SPI decoder isn't configured properly, that's not a problem for me
Here's how you should configure it:
(note this can vary depending how your probes are connected ...)
Last edit: 18 Apr 2016 14:42 by goebish.
- 92zb
18 Apr 2016 15:42 #46742
by 92zb
How about these captures for Headless Mode
www.mediafire.com/download/vet2ygkescat2...P-HEADLESS-ON-OFF.7z
www.mediafire.com/download/sbgjtvh7bh9ca...N-HEADLESS-ON-OFF.7z
This Q-copter goes into headless mode regardless of positgion of throtle.
- goebish
- NRF Weirdo
18 Apr 2016 15:52 #46743
by goebish
Ok, I think I see it.
It's using the same flag than for video recording on MT99XX, so headless should work on channel 8 with the test build I posted.
Can you check that ?
- goebish
- NRF Weirdo
18 Apr 2016 15:55 #46744
by goebish
No, according to the captures it doesn't
92zb wrote: This Q-copter goes into headless mode regardless of positgion of throtle.
- 92zb
18 Apr 2016 16:31 #46748
by 92zb
I have 7e which only 6 channels.
- goebish
- NRF Weirdo
18 Apr 2016 16:32 #46749
by goebish
No, you're using Deviation, so you've 12 channels
Just map a switch to channel 8 in the mixer.
- 92zb
18 Apr 2016 19:42 #46752
by 92zb
Sorry to be a lame duck. How do you map a switch or channel in 7e. I haven't got a clue. I have searched every where, could not find any answer.
- goebish
- NRF Weirdo
18 Apr 2016 20:00 - 18 Apr 2016 20:06 #46754
by goebish
Hmmm, there's a User Manual you know
www.deviationtx.com/user-manual/user-manual-7e-10
Go to the Mixer screen, then highlight "None" next to Ch8 then press ENT:
Now highlight "None", then change it to "Simple":
Then for Src, select "HOLD1" for example:
Then don't forget to select "Save" then press ENT:
Now you can check in channel monitor screen that Ch8 is in high position when Hold switch is down (HOLD1).
Last edit: 18 Apr 2016 20:06 by goebish.
- 92zb
18 Apr 2016 20:33 #46755
by 92zb
I just teseted using Ch8, you can go into headless mode immediately after binding and come out of it with a flick of the same switch.
I will test flip outside the house, when the weather is calm
- goebish
- NRF Weirdo
18 Apr 2016 20:36 - 18 Apr 2016 20:40 #46756
by goebish
Flip is on channel 6, but it will work only if it's using the same flag than MT99 / H7, if it doesn't work you'll have to make another capture
Also, I'll move headless to Channel 9, so it's the same than other protocols.
Last edit: 18 Apr 2016 20:40 by goebish.
- goebish
- NRF Weirdo
18 Apr 2016 20:38 - 18 Apr 2016 20:39 #46757
by goebish
... and no hurry, the protocol isn't ready for nightly anyway, I've to optimize the "extended" xn297 layer because it doesn't fit in the 7e as it is.
(well, it does with the old compiler I'm using, but not with the newer one...)
Last edit: 18 Apr 2016 20:39 by goebish.
- 92zb
19 Apr 2016 15:27 #46799
by 92zb
Yes I confirm it does flip using Ch6
- goebish
- NRF Weirdo
19 Apr 2016 15:29 #46800
by goebish
Ok thanks, I'll try to work on the size issue I had with xn297 "unscrambled" mode so it can be included in nightly build.
Meanwhile, just use this test build
Time to create page: 0.331 seconds
- LIANSHENG LS114 4CH 2.4GHz RTF UFO Drone SPI DATA
