LIANSHENG LS114 4CH 2.4GHz RTF UFO Drone SPI DATA
19 Apr 2016 16:21 #46806 by 92zb
Please let me know when you incorporate into the nightly build. Thanks.
20 Apr 2016 12:32 #46862 by 92zb
Hi, by the way, how do you control speed. What I mean is the sensetivity of the Throtle stick, from learner to expert mode.
20 Apr 2016 12:35 #46864 by goebish
We don't implement that in Deviation, just use scale rate and expo as required.
20 Apr 2016 22:37 #46904 by 92zb
Hi goebish, great tutorial, thank you very much.
01 May 2016 13:31 #47542 by 92zb
Hi goebish
Version 5 has just been released. Is this LS144 included in this release or I have to wait for a nightly, thanks.
03 May 2016 19:13 #47692 by 92zb
Hi, I was just playing with the above q.copter, I noticed that non of the timers are working. In fact there only two timers, Permenant and Countdown. The Countdown gives error, it buzes continously. Just to let you know. By the way I am still on 4.1 and your test built.
14 May 2016 11:31 #48410 by goebish
14 May 2016 12:56 #48424 by goebish
It's just been merged into trunk, so it should appear in the nightlies soon :)
14 May 2016 16:43 #48442 by 92zb
GREAT, thanks.
17 May 2016 16:50 #48599 by 92zb
Hi geobish, I am having problem with this copter since it has been incorporated into the nightly.. It drift very severly to down and left, no matter how how much trim you apply. Hope you can have a look at it. Thanks.
17 May 2016 16:55 - 17 May 2016 17:09 #48600 by goebish
The code is exactly the same than in the previous test build.
- Recalibrate Devo sticks then LS114 accelerometer:
www.rcgroups.com/forums/showpost.php?p=30087605&postcount=31
- Go to the trims page then set steps to 1.0 instead of default 0.1
That could also happen because of vibrations (bad props ?) or defective motor (back left).
Last edit: 17 May 2016 17:09 by goebish.
17 May 2016 20:29 #48606 by 92zb
I tried by increasing the trims to 100 with very little effect. I forgot to mention that I tried with the original TX, no problem. I have two of these, one with headless mode. The headless mode one would not fly forward, always flying backword, the other one I managed to fly but it tumbls on its own.
Time to create page: 0.066 seconds
