LIANSHENG LS114 4CH 2.4GHz RTF UFO Drone SPI DATA
13 Apr 2016 23:35 - 16 Apr 2016 23:00 #46454 by goebish
I had a further look and as I thought this is similar to the MT99xx / H7 protocol except that it always transmits on the same channel.
I'll implement it and post a test firmware.
I also have to find why the optimized xn297 crc algo didn't work last time I had a look at it ... worst case I'll remove the i6S format option (the only one that's using xn297 unscrambled mode) for now.
Last edit: 16 Apr 2016 23:00 by goebish.
16 Apr 2016 22:54 #46666 by goebish
I'll try to do it very soon™, sorry, so much stuffs to explore, so little time ;)
17 Apr 2016 23:47 #46725 by goebish
Here's a test build, select MT99XX protocol then LS114 format option:
Devo 7e: www.dropbox.com/s/j1gpx1wom6zmdwo/deviat...evo7e-ls114.zip?dl=0
Devo 10: www.dropbox.com/s/cafwolo7x0j1hdi/deviat...evo10-ls114.zip?dl=0
18 Apr 2016 04:57 #46730 by 92zb
Yes it works. A bit more sensative and a tendency to Yaw anti-clock wise. I have not tested in headless mode, or flips, cus I do not know the switch it requres.
I also have LS124 which is not head less, it also binded succesfully.
There is a file in your test build "debug-Devo7e-Unknown.zip", what is this for.
18 Apr 2016 09:22 - 18 Apr 2016 11:27 #46733 by goebish
Cool :)
You don't need the zip that's inside the zip, it's only useful to developers.
Headless is not implemented because there was no trace of it in your capture (I think it doesn't trigger when throttle is low), I think you'll have to make another one.
For flips, try channel 6, it should work if it's using the same flag than MT99/H7, otherwise you'll have to make another capture.
Regarding Yaw, you had a lot of right trim on your stock transmitter, if you feel you can't set enough trim, go to the Trims screen then set 1.0 steps instead of default 0.1
Last edit: 18 Apr 2016 11:27 by goebish.
18 Apr 2016 14:23 #46740 by 92zb
Hi goebish, thank you very much for your help, I appreciate it very much and I am sure all those who have these q-copter.
I have captured some more, please have a look, if there is any more data you want, let me know.
www.mediafire.com/download/qh6gwgu8qxu91...ERT-HEADLESS-MODE.7z
www.mediafire.com/download/n2y3zj7pbojrnbo/RUDDER_LEFT_TRIM.7z
www.mediafire.com/download/npb8xopxq5t3y2a/RUDDER_RGHT-TRIM.7z
www.mediafire.com/download/f9ewhf1bd02rr...UP-DWN-RIGHT-LEFT.7z
www.mediafire.com/download/2vvici86shovfg6/HEADLESS_MODE.7z
www.mediafire.com/download/glaa6jm0ur5lgbj/EXPERT_MODE.7z
By the way what is this miss matching of data, should I be concerned and how can I avoid it in future capture.
Thanks for your help.
18 Apr 2016 14:33 - 18 Apr 2016 14:42 #46741 by goebish
There's still nothing interesting in your "HEADLESS_MODE" capture, I think that's because throttle is down.
Give some throttle before capturing that (the copter doesn't need to be turned on ...)
You're having mismatch / errors because your SPI decoder isn't configured properly, that's not a problem for me ;)
Here's how you should configure it:
(note this can vary depending how your probes are connected ...)
Last edit: 18 Apr 2016 14:42 by goebish.
18 Apr 2016 15:42 #46742 by 92zb
How about these captures for Headless Mode
www.mediafire.com/download/vet2ygkescat2...P-HEADLESS-ON-OFF.7z
www.mediafire.com/download/sbgjtvh7bh9ca...N-HEADLESS-ON-OFF.7z
This Q-copter goes into headless mode regardless of positgion of throtle.
18 Apr 2016 15:52 #46743 by goebish
Ok, I think I see it.
It's using the same flag than for video recording on MT99XX, so headless should work on channel 8 with the test build I posted.
Can you check that ?
18 Apr 2016 15:55 #46744 by goebish
92zb wrote: This Q-copter goes into headless mode regardless of positgion of throtle.
No, according to the captures it doesn't ;)
18 Apr 2016 16:31 #46748 by 92zb
I have 7e which only 6 channels.
18 Apr 2016 16:32 #46749 by goebish
No, you're using Deviation, so you've 12 channels ;)
Just map a switch to channel 8 in the mixer.
18 Apr 2016 19:42 #46752 by 92zb
Sorry to be a lame duck. How do you map a switch or channel in 7e. I haven't got a clue. I have searched every where, could not find any answer.
18 Apr 2016 20:00 - 18 Apr 2016 20:06 #46754 by goebish
Hmmm, there's a User Manual you know ;)
www.deviationtx.com/user-manual/user-manual-7e-10
Go to the Mixer screen, then highlight "None" next to Ch8 then press ENT:
Now highlight "None", then change it to "Simple":
Then for Src, select "HOLD1" for example:
Then don't forget to select "Save" then press ENT:
Now you can check in channel monitor screen that Ch8 is in high position when Hold switch is down (HOLD1).
Last edit: 18 Apr 2016 20:06 by goebish.
18 Apr 2016 20:33 #46755 by 92zb
I just teseted using Ch8, you can go into headless mode immediately after binding and come out of it with a flick of the same switch.
I will test flip outside the house, when the weather is calm
18 Apr 2016 20:36 - 18 Apr 2016 20:40 #46756 by goebish
Flip is on channel 6, but it will work only if it's using the same flag than MT99 / H7, if it doesn't work you'll have to make another capture ;)
Also, I'll move headless to Channel 9, so it's the same than other protocols.
Last edit: 18 Apr 2016 20:40 by goebish.
18 Apr 2016 20:38 - 18 Apr 2016 20:39 #46757 by goebish
... and no hurry, the protocol isn't ready for nightly anyway, I've to optimize the "extended" xn297 layer because it doesn't fit in the 7e as it is.
(well, it does with the old compiler I'm using, but not with the newer one...)
Last edit: 18 Apr 2016 20:39 by goebish.
19 Apr 2016 15:27 #46799 by 92zb
Yes I confirm it does flip using Ch6
19 Apr 2016 15:29 #46800 by goebish
Ok thanks, I'll try to work on the size issue I had with xn297 "unscrambled" mode so it can be included in nightly build.
Meanwhile, just use this test build ;)
Time to create page: 0.120 seconds
