Eachine E010 inductrix clone data captures
09 Dec 2016 16:01 #56710 by goebish
Replied by goebish on topic Eachine E010 inductrix clone data captures
Are you using a x-in-1 module or a separate nrf24l01+ ?
Looks like the x-in-1 modules are having issues emulating XN297L at 250kbps ... unfortunately there's nothing much I can do about that.
09 Dec 2016 16:01 #56711 by victzh
Replied by victzh on topic Eachine E010 inductrix clone data captures
@SodaAnt similar to what? Are you sure you're writing in the right thread? And what is 10e?
09 Dec 2016 16:05 #56712 by SodaAnt
Replied by SodaAnt on topic Eachine E010 inductrix clone data captures
goebish wrote: Are you using a x-in-1 module or a separate nrf24l01+ ?
Yeah, that seems like it may be the issue. I do think I have a spare nrf24l01+ board lying around, maybe it is possible to solder that into the tx in addition to the 3 in 1 module, but designate the new pins as the ones for the nrf in the config file?
victzh wrote: @SodaAnt similar to what? Are you sure you're writing in the right thread? And what is 10e?
Yes, meant to quote a post and failed. The binding issues on anything but very low powers that some people were seeing. The 10E is simply the devo 10, but white and a bit higher dBi antenna.
09 Dec 2016 16:10 #56713 by goebish
SodaAnt wrote: Yeah, that seems like it may be the issue. I do think I have a spare nrf24l01+ board lying around, maybe it is possible to solder that into the tx in addition to the 3 in 1 module, but designate the new pins as the ones for the nrf in the config file?
You'll have to disconnect the nrf24 csn pin from the x-in-1 module to connect the one from the separate module instead.
09 Dec 2016 16:14 #56714 by goebish
Also, try with a few different transmitter IDs, maybe it will work better with a different set of frequencies, that's worth a try ...
09 Dec 2016 16:18 #56716 by goebish
@victzh, interesting post regarding a x-in-1 module, nrf24l01 and a xn297l @ 250kbps protocol:
www.deviationtx.com/forum/protocol-devel...-q303?start=80#56342
09 Dec 2016 17:05 - 09 Dec 2016 17:10 #56720 by ajtank
Replied by ajtank on topic Eachine E010 inductrix clone data captures
A possible fix to this issue is to change the two loading capacitors of the crystal to 15pF. I am running some more experiments on Q303 and will come to a conclusion very soon. Anybody having problem using nRF24L01 of 4-in-1 module to emulate XN297L in 250kbps mode can give this a try.
Last edit: 09 Dec 2016 17:10 by ajtank.
13 Dec 2016 13:45 - 15 Dec 2016 16:09 #56776 by planger
Replied by planger on topic Eachine E010 inductrix clone data captures
More IDs vs Frequencies:
NumID/Freq
00x4F0x1C0x00/0x3A0x350x4A0x45
10x900x1C0x00/0x2E0x360x3E0x46
20x240x360x00/0x320x3E0x420x4E
30x7A0x400x00/0x2E0x3C0x3E0x4C
40x610x310x00/0x2F0x3B0x3F0x4B
50x5D0x370x00/0x330x3B0x430x4B
60xFD0x4F0x00/0x330x3B0x430x4B
70x860x3C0x00/0x340x3E0x440x4E
80x410x220x00/0x3F0x340x2F0x44
90xEE0xB30x00/0x390x3E0x490x4E
100x9A0xB20x00/0x2E0x380x3E0x48
110x3C0xCD0x01/0x320x3E0x420x4E
120xC00x440x00/0x2E0x360x3E0x46
130x2A0xFE0x00/0x2E0x380x3E0x48
140xD70x6E0x00/0x3A0x410x4A0x51
150xF50x2B0x02/0x330x3F0x430x4F
Pascal
Last edit: 15 Dec 2016 16:09 by planger. Reason: 2 bad entries...
13 Dec 2016 13:46 #56777 by goebish
Thanks, I'll add them to Deviation and nrf24-multipro :)
13 Dec 2016 16:48 - 13 Dec 2016 16:53 #56795 by goebish
I'll remove pairs with duplicate channel list (quite a few of them for only 15 dumps !) because flying more than 1 E010 with transmitters that are using the same frequencies is an issue: github.com/goebish/nrf24_multipro/issues/17
Interferences have also a good chance to happen with stock transmitters, looks like they're using a fixed list of 16 or so channel sequence ...
Last edit: 13 Dec 2016 16:53 by goebish.
14 Dec 2016 17:01 #56821 by victzh
But please keep this list somewhere - it may help guessing the algorithm of producing frequency hopping (actually - two frequencies, other two are deduced) from id.
14 Dec 2016 18:59 - 14 Dec 2016 19:00 #56824 by goebish
Do we have a consensus of how many tx id / channels pairs are required to add a protocol to Deviation when we've not figured out the algo yet ?
I've a few uncommited protocols because I've only 1-2 tx id ...
Last edit: 14 Dec 2016 19:00 by goebish.
14 Dec 2016 19:52 #56826 by FDR
I think it is a question of documentation.
If you add a comment about that in the supported model list, every protocol is useful even if only one channel set is known...
14 Dec 2016 19:56 #56827 by victzh
I agree with FDR. Also, protocol visibility raises chances of other people providing us with more Id data.
15 Dec 2016 12:22 #56839 by FabioKastro
Replied by FabioKastro on topic Eachine E010 inductrix clone data captures
My Devo only binds to the E010 at 10mW and it has a bad delay. Is that because of the 3in1 not being able to simulate whatever you guys said above?
15 Dec 2016 12:24 - 15 Dec 2016 12:25 #56840 by goebish
Probably, looks like a fix is to replace the 2 capacitors (size 0402, value 15pF) that are located near the oscillator of the nrf24l01:
www.deviationtx.com/forum/protocol-devel...q303?start=100#56818
But first, try with a few different transmitter ID.
Last edit: 15 Dec 2016 12:25 by goebish.
15 Dec 2016 15:32 #56846 by planger
FabioKastro wrote: My Devo only binds to the E010 at 10mW and it has a bad delay. Is that because of the 3in1 not being able to simulate whatever you guys said above?
This is also caused by bad antennas. Try another one.
Pascal
15 Dec 2016 16:05 - 15 Dec 2016 16:11 #56847 by ajtank
Here is the capture of my E010 transmitter.
Last edit: 15 Dec 2016 16:11 by ajtank.
15 Dec 2016 16:10 #56849 by planger
Thanks, I've updated the table above.
Pascal
15 Dec 2016 16:12 #56850 by goebish
I've already tried hard but I can't find the logic ... oh well, this list is good enough :)
Time to create page: 0.204 seconds
