XT001a (XT Flyer/Arshiner)
- brylant
19 Dec 2016 11:19 #56977
by brylant
XT001a (XT Flyer/Arshiner) was created by brylant
Does anybody know if the protocol for XT001a is available...?
- brylant
20 Jan 2017 13:19 #58232
by brylant
Replied by brylant on topic XT001a (XT Flyer/Arshiner)
anybody...? there must be somebody out there using xt001a with the devo...
- goebish
- NRF Weirdo
21 Jan 2017 03:15 #58268
by goebish
Replied by goebish on topic XT001a (XT Flyer/Arshiner)
Never heard of it before ...
Try every protocols with every format options, if neither works then read this thread:
www.deviationtx.com/forum/protocol-devel...95-spi-capture-guide
- Nagolite
06 Feb 2017 11:34 - 06 Feb 2017 17:30 #58815
by Nagolite
Replied by Nagolite on topic XT001a (XT Flyer/Arshiner)
Try CX10, I've bound to my XT001A using several of the sub formats under that... Channel 5 triggers flip mode, but I've not been able to successfully tweak Channel 6 for toggling Safe/Speed flight modes yet. Maybe you can find the sweet spot mix and share!
Successfully bound with CX10 using:
GREEN
DM007
JC3015_1
JC3015_2
MK33041
Cheers and good luck!
GREEN
DM007
JC3015_1
JC3015_2
MK33041
Last edit: 06 Feb 2017 17:30 by Nagolite.
- Nagolite
06 Feb 2017 22:16 - 13 Feb 2017 21:52 #58832
by Nagolite
I setup tri-rates on a 3pos switch (50/75/100) and put channel 5 (flips) on a momentary switch. Channel 5 will trigger flips if the pitch/roll input weight is 60 or higher, so in my low rate (50) the flip switch has no effect. The only hiccup so far is if I trigger flips in low rate it won't flip; however, if I then switch up to 75 or 100 the very first pitch/roll input will execute that pending flip that didn't happen while at 50.
The 001A's control board holds the 'pending flip' for longer than 60 seconds, not sure if it ever times out and resets. However, if you drop throttle to zero it will cancel the pending flip request (so landing or a mid-air drop/recover can reset the triggered flip input).
Last edit: 13 Feb 2017 21:52 by Nagolite.
Time to create page: 0.121 seconds
- XT001a (XT Flyer/Arshiner)
