Mjx Bugs 3
- DPyro
24 May 2018 22:52 #69401
by DPyro
Replied by DPyro on topic Mjx Bugs 3
I'm not getting a fixed id on a bugs 3 mini.
- Exiter
- JayDrone
26 May 2018 04:39 #69413
by JayDrone
Replied by JayDrone on topic Mjx Bugs 3
ok so i have it on the black and silver model I can get a fixed id number and have tryed it on 2 diff bugs 3s I have both come up with a negitive fixed id number and the toggles wont do anything any sugjestions please
- JayDrone
26 May 2018 05:27 #69414
by JayDrone
UPDATE got it situated I have it bound to the mjx bugs drocon 3 as well as a 1st gen bugs 3 will be binding to many others I have a full line up of them
- JayDrone
26 May 2018 17:47 #69421
by JayDrone
ok I have bugs on the jumper thank you -- is there any wat to increase the pitching as it seems to be same or less than stock controller -- or is it possable to create a new file to put on t8sg for much greater pitching SAY a turbo bugs 3 protocol -- ??
- mmakai
26 May 2018 18:51 #69422
by mmakai
Replied by mmakai on topic Mjx Bugs 3
In a previous post hexfet decided to not work on different speed modes (at least in the current state of development), that can be handled in the mixer. Those some weeks while hexfet returns to bugs 3 protocol development is a good opportunity to gather possible problems of the current implementation from the testers.
- JayDrone
27 May 2018 01:59 #69427
by JayDrone
the drone flys well but i think added speed or pitch values would be nice -- sure i tryed 125% and just didnt seem to pick up that much pitching idk
- davdrone1
- davdrone1
29 May 2018 01:52 #69451
by davdrone1
Time flies like a banana
Replied by davdrone1 on topic Mjx Bugs 3
Hi Guys,
My original Bugs 6 binds using the Bugs3 protocol. Turns out I made a transcription error entering the Tx ID with an earlier build.
I detected this using the auto lookup version.
Jaydrone has just put up a video demonstration that the new Bugs 8 Pro will also bind with the Bugs3 protocol.
Getting more useful every day ....
- JayDrone
29 May 2018 02:10 #69452
by JayDrone
yes the bugs 8 pro i just put on it -- I did hover test works well the lvc on the drone also works on the drone as to be expected and loss of connection from t8sg alarm will also sound i will do flight video in some time
- DPyro
30 May 2018 00:51 #69469
by DPyro
If it's working on all these other versions am I doing something wrong on the bugs 3 mini?
- C0ckpitvue 777
- JayDrone
30 May 2018 00:54 #69471
by JayDrone
no ur not the mini and the bugs 3h are not on the same protocol and wil not work with the t8sg off of this dfu file
- C0ckpitvue 777
- DPyro
- C0ckpitvue 777
- goebish
- NRF Weirdo
01 Jun 2018 12:58 #69503
by goebish
Replied by goebish on topic Mjx Bugs 3
Ground is common, you could have soldered to battery -
- C0ckpitvue 777
01 Jun 2018 16:53 #69508
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Mjx Bugs 3
Wow,I never knew that,thanks appreciate it.
- goebish
- NRF Weirdo
01 Jun 2018 17:33 #69509
by goebish
By the way, I've been lurking this thread, very good job hexfet! That's not an easy one ...
- C0ckpitvue 777
01 Jun 2018 23:35 #69510
by C0ckpitvue 777
I just took this capture of the b3 mini bind sequence,would like to know if it's good so I can proceed with the captures,if anyone with experience in reading captures look at them it will be greatly appreciated.
www.mediafire.com/file/kw0tkodqbtrv622/T...0on%20Bind.logicdata
02 Jun 2018 22:52 #69523
Replied by hexfet on topic Mjx Bugs 3
Can't download from that link. Clicking the green button opens a pop-under and never starts a download. If you put it in a .zip you can probably upload it here.
For the control travel we can revisit the driven trims and see if the problem is just wrong directions. Someone please post a bugs3 model file so I can see which channels are reversed.
mmakai, nice work on the rxid mapping. Not sure what's best for the memory requirement. Probably okay if it's just not added to the limited-memory builds.
Time to create page: 1.502 seconds
- Mjx Bugs 3
