JJRC H8DH - POTENSIC F183DH - (unknown protocol)
24 Oct 2017 19:03 #65232 by Elric
Test with all known procotole: no binding
Function to maintain the altitude in addition to the JJRC H8D
TX chip :
How to wire this tx chip for capture?
24 Oct 2017 19:24 #65233 by Moeder
How convenient...they even labeled where to wire: MOSI, MISO, CSN, SCK and not to forget GND are your targets.
25 Oct 2017 20:22 #65266 by Elric
Thank you, I would capture the Saturday morning that comes
28 Oct 2017 08:30 - 29 Oct 2017 18:08 #65318 by Elric
Capture 8MHz : 1drv.ms/u/s!AuNBpmXL1y0Rg8tnFJENYCjjGbc4ew
Channels of capture :
MOSI => CH1
MISO => CH2
SCK => CH3
CSN => CH4
GND => GND
OFF => ON => binding => start motor => CH1 => CH2 => CH4 => CH3 => Light => video => photo => headless/return to home => flips => off
Last edit: 29 Oct 2017 18:08 by Elric.
29 Oct 2017 21:56 #65351 by goebish
Seems this is a CX-10 variant, can you try with all its sub-formats ?
If it's doesn't work I'll make a test build with the same RF channels than in your dump, and if it still doesn't work I'll also copy your TX ID, but that means that only one deviated H8DH could fly in a given area.
29 Oct 2017 22:29 #65352 by goebish
Try this build, it has an H8DH format for CX-10 protocol:
www.dropbox.com/sh/4idi2nlmqs02rye/AABKd...GK9JlzsJQH0q-ba?dl=0
Let me know if it binds, functions are not implemented yet.
29 Oct 2017 22:47 - 29 Oct 2017 23:00 #65354 by Elric
I tested all the CX10s and none of them bind.
the same for CX10-H8DH.
Last edit: 29 Oct 2017 23:00 by Elric.
29 Oct 2017 22:51 - 29 Oct 2017 22:52 #65355 by goebish
Ok, build updated to include the txid that's in your dump:
Last edit: 29 Oct 2017 22:52 by goebish.
29 Oct 2017 23:04 - 29 Oct 2017 23:07 #65356 by Elric
the leds stop flashing quickly from the beginning of the pairing. then she blinks slowly as if the drone were waiting for something.
to arm the drone, I have to play with the throttle stick (up and down) so that the leds become fixed.
Last edit: 29 Oct 2017 23:07 by Elric.
29 Oct 2017 23:10 - 29 Oct 2017 23:15 #65357 by goebish
Ok, I suppose it's waiting for the flags that are not implemented yet.
When you say "start motor" in your capture, does that mean you've to press a button ?
Also, please make 1 capture per function, that's really more convenient, there are too many stuffs in your capture, I can't see what is what ;)
Last edit: 29 Oct 2017 23:15 by goebish.
30 Oct 2017 22:09 #65370 by Elric
Start motors with a button
New Capture 8MHz (one file = off + on + binding + one function) : 1drv.ms/u/s!AuNBpmXL1y0Rg8tvry_6avxpMkh5tg
Starting engines is also possible by lowering the sleeves in the center.
30 Oct 2017 22:21 #65371 by goebish
Thanks, I should be able to make it work with that, I think only 1 thing is missing: the different rates ("Bounless speed variable" button ?).
13 Nov 2017 14:51 - 13 Nov 2017 14:54 #65794 by goebish
I updated the test build:
Protocol: CX10, Format: H8DH
Ch5: leds
Ch6: flips
Ch7: snapshot
Ch8: video
Ch10: "RTH" (at least they're honest, they call it "headless fly back mode" :p)
Ch12: motor start / stop
Please report.
If it works I'll need a capture with the different rates to finalize the implementation.
Last edit: 13 Nov 2017 14:54 by goebish.
Time to create page: 0.207 seconds
