Bugs 3 mini
13 Oct 2018 14:12 #71315 by goebish
Replied by goebish on topic Bugs 3 mini
Test build updated, angle/acro mode should be working now.
13 Oct 2018 14:16 #71316 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Bugs 3 mini
Thanks,will give it a shot..
13 Oct 2018 14:20 #71317 by C0ckpitvue 777
Is the fix in the same build..
13 Oct 2018 14:31 - 13 Oct 2018 14:32 #71318 by goebish
same link, but new files.
(27dc771)
Last edit: 13 Oct 2018 14:32 by goebish.
13 Oct 2018 14:53 #71320 by C0ckpitvue 777
goebish wrote: Test build updated, angle/acro mode should be working now.[/quote
Confirmed,Acro is working just like stock,We can't transition from acro to angle in flight,it has to be rebound in it's respective mode.Something else also to note the disarm won't work if the throttle has value.So warning to all novice,shut your throttle fully down in order to disarm it with channel 5.Awesome job Goebish,thanks again..
13 Oct 2018 16:04 #71321 by DPyro
Replied by DPyro on topic Bugs 3 mini
Too bad we can't modify the firmware on the quad.
13 Oct 2018 17:42 #71323 by goebish
Just use another FC, that should be possible to use a H8 Mini / Boldclash B03 / EAchine E011 FC flashed with silverware and connected to stock ESCs ...
13 Oct 2018 17:46 #71324 by goebish
Build updated with telemetry
- RSSI (not sure it's really useful, to be tested)
- Battery voltage alarm
Battery voltage has only 3 levels:
8.40V: Ok
7.10V: Warning
6.40V: Critical
I also added the txid / rf channels we have (4), a rebind may be required.
13 Oct 2018 18:23 - 13 Oct 2018 18:31 #71326 by goebish
C0ckpitvue 777 wrote: Something else also to note the disarm won't work if the throttle has value.So warning to all novice,shut your throttle fully down in order to disarm it with channel 5.
I'll fix that ...
edit: fixed.
Last edit: 13 Oct 2018 18:31 by goebish.
13 Oct 2018 21:03 #71327 by C0ckpitvue 777
Thank you Goebish..
13 Oct 2018 23:06 #71329 by C0ckpitvue 777
Thanks Goebish,I just flew with the devo 10 with build dd90e6a and the flips wouldn't turn off after enabled,in other words if I gave it too much stick in either direction it would flip.It would happen if you would bind the quad to the tx with channel 7 enabled and once in flight you cannot disable it.I was also doing some funnels and the bugs would act eratic like it got gyro drunk.I will simulate this with the stock tx tomorrow to see if I get the same behavior.
14 Oct 2018 09:08 #71333 by goebish
Let me know if I should disable the flip flag while the quad is disarmed, but on stock transmitter it can be enabled anytime, stock transmitter doesn't know if the quad is armed (but Deviation does).
14 Oct 2018 14:53 #71335 by C0ckpitvue 777
goebish wrote: Let me know if I should disable the flip flag while the quad is disarmed, but on stock transmitter it can be enabled anytime, stock transmitter doesn't know if the quad is armed (but Deviation does).[/qu
If it fixes the in flight glitch where we can't toggle it off,I think disabling it would be the best option.
14 Oct 2018 15:51 #71336 by goebish
ok, build updated.
14 Oct 2018 18:45 #71338 by C0ckpitvue 777
goebish wrote: ok, build updated.
Thanks bro,your hard work and time is greatly appreciated.I will update everything with the telemetry and do a test flight..
15 Oct 2018 04:07 #71348 by C0ckpitvue 777
Just tried the latest build with my devo 10 and it spontaneously had phantom inputs especially with the throttle.It would also lose bind while sitting idle and it would beep.
15 Oct 2018 08:44 #71350 by goebish
Ok, I've to check if this is because of a wrong timing for telemetry or using a different txid / rf channels set.
15 Oct 2018 10:56 #71353 by goebish
I can't reproduce the issue.
I added 2 test builds for Devo10, one is fixed_id, the other one no_telemetry, can you tell me if one of them fixes the problem ?
15 Oct 2018 12:55 #71356 by C0ckpitvue 777
goebish wrote: I can't reproduce the issue.
The no telemetry file seemed to fix it,the fixed id file was still a bit twerky..
15 Oct 2018 12:57 - 15 Oct 2018 13:01 #71357 by goebish
Ok thanks, well, I prefer that, that should be a simple fix, I'm probably shutting down the transmitter too soon when switching to rx mode ...
Last edit: 15 Oct 2018 13:01 by goebish.
Time to create page: 0.156 seconds
