Bugs 3 mini
- C0ckpitvue 777
15 Oct 2018 13:03 #71358
by C0ckpitvue 777
No problem,I will continue to test them and give you feedback,,
Replied by C0ckpitvue 777 on topic Bugs 3 mini
goebish wrote: Ok thanks, well, I prefer that, that should be a simple fix, I'm probably shutting down the transmitter too soon when switching to rx mode ...
- goebish
- NRF Weirdo
- C0ckpitvue 777
15 Oct 2018 14:38 #71361
by C0ckpitvue 777
Thanks I'll give it a go,
goebish wrote: Updated
- planger
15 Oct 2018 16:37 - 15 Oct 2018 17:10 #71363
by planger
Here are the rxid causing issues which are easy to pinpoint: 0500,0af9,3010,3048,305a,30b9,8c30,d830,eb30,61a3,6d97
For example, 3010 -> 3d 10 a9 ce 00 where it should be 30 3d 10 a9 ce . Others in the list have either a mising byte or what looks like to be an old buffer entry.
There are a couple more which looks abnormal than the list above but the ones provided are for sure bad.
I'm progressing on reversing the table. It's based on a circular buffer as stated previously.
Pascal
Replied by planger on topic Bugs 3 mini
There are a number of bad values in the excel file. Are you able to redo some of them?goebish wrote: @Pascal, awesome! Feel free to do it if you understand how it works, no hurry.
Pascal
Last edit: 15 Oct 2018 17:10 by planger.
- goebish
- NRF Weirdo
15 Oct 2018 17:09 - 15 Oct 2018 17:15 #71364
by goebish
Replied by goebish on topic Bugs 3 mini
I noticed there was a few errors the first time I dumped it, I fixed a few manually but probably missed some.
I made a 2nd capture which should be fine (more checks), it's in my dropbox folder:
www.dropbox.com/sh/nrc4oppo121887l/AABQ_...IEn8A7BYvH5BpGa?dl=0
3010,30 3d 10 a9 ce ,12304,-50
Last edit: 15 Oct 2018 17:15 by goebish.
- C0ckpitvue 777
15 Oct 2018 19:15 #71368
by C0ckpitvue 777
I just flew it hard with the devo 10,no noticeable flaws in flight characteristics but if you enable channel 7 .flip channel,it's still misbehaving the same.
- goebish
- NRF Weirdo
15 Oct 2018 19:32 #71369
by goebish
Updated, that should fix the issue with flip channel.
- JayDrone
15 Oct 2018 20:56 #71370
by JayDrone
Replied by JayDrone on topic Bugs 3 mini
im willing to try it on the t8sg plus where can I find the dfu file to update the t8sg plus to have b3mini
- goebish
- NRF Weirdo
15 Oct 2018 21:09 #71372
by goebish
For now you've to follow those steps:
www.deviationtx.com/forum/protocol-devel...mini?start=100#71282
- JayDrone
15 Oct 2018 21:15 #71373
by JayDrone
any one have a vid on how to do that im not a novic but when it comes to that spreadsheet im a bit lost
- JayDrone
15 Oct 2018 21:22 #71374
by JayDrone
i think i got most of it besides last steps a vid would be great
- goebish
- NRF Weirdo
15 Oct 2018 21:23 - 15 Oct 2018 21:25 #71375
by goebish
Just follow the steps, you only have to find the line with your rxid in the green column then write down the number that's in the blue column.
... or just wait, the spreadsheet shouldn't be required anymore soon.
Last edit: 15 Oct 2018 21:25 by goebish.
- goebish
- NRF Weirdo
15 Oct 2018 21:30 #71376
by goebish
if you can't edit your modelxx.ini file you can enter the number from the blue column in the protocol option dialog (Address), but it can be long if this is a large number
- JayDrone
15 Oct 2018 21:36 #71377
by JayDrone
apreciate ur time -- where do i find the protocol option dialog (Address) to enter the number into -
- JayDrone
15 Oct 2018 21:39 #71378
by JayDrone
apreciate ur time -- where do i find the protocol option dialog (Address) to enter the number into - also im in no rush by any means bro - just figured if i ould get it bound i could test fly it -- if i cant figure it out again no rush at ll can wait till u guys have a more direct way of binding
- C0ckpitvue 777
15 Oct 2018 21:40 #71379
by C0ckpitvue 777
Not that it matters to me,I can really do Without the flip channel but for the heads up,it still doesn't disable once enabled in a bind sequence...
goebish wrote: Updated, that should fix the issue with flip channel.
- goebish
- NRF Weirdo
15 Oct 2018 21:49 #71381
by goebish
In the same screen where you found the Rx id, by pressing ENT when the protocol name is highlighted.
JayDrone wrote: apreciate ur time -- where do i find the protocol option dialog (Address) to enter the number into -
- JayDrone
- goebish
- NRF Weirdo
15 Oct 2018 21:53 #71383
by goebish
That's weird, but I suppose it also happens with stock Tx.
Just remember to arm with flip channel disabled
C0ckpitvue 777 wrote: Not that it matters to me,I can really do Without the flip channel but for the heads up,it still doesn't disable once enabled in a bind sequence...
- goebish
- NRF Weirdo
15 Oct 2018 21:55 #71384
by goebish
No, the "Rx Id" that's in the protocol option dialog ... That's the number you have to find in the spreadsheet, if you looked for the number in fixed id you got it wrong.
JayDrone wrote: the fixed id #??
Time to create page: 0.326 seconds
- Bugs 3 mini
