Tricopter flips when throttle only is used devo10
- minaton
11 Aug 2015 16:06 #36781
by minaton
Tricopter flips when throttle only is used devo10 was created by minaton
i have a HJ-Y3 Glass Fiber Tricopter, fitted with kk2 2.15 flight control, sunny sky x22045 2300kv motors, 6x4.5 props and voltech magic 30amp simon k BEC and my transmitter is a Devo 10 , my problem is when i try to take off the trycopter flips to the left on to its back, all motors and props are turning the right way and are fitted correctly and the BEC.S are in the correct place and calibrating with my KK2 Board can anyone help please with setting for devo 10 setting for a tricopter ty
- SirDomsen
11 Aug 2015 16:17 #36783
by SirDomsen
Replied by SirDomsen on topic Tricopter flips when throttle only is used devo10
Which receiver do you use? Are you using deviation or stock firmware? Did you setup the FC correctly and is it receiving all channels properly (monitored in the GUI)?
- minaton
11 Aug 2015 16:55 #36789
by minaton
Replied by minaton on topic Tricopter flips when throttle only is used devo10
hi i have a white DEVENTION DEVO 10 , Software ver, 0,8a Library Ver 0.2 . all stick movements are corret
- minaton
11 Aug 2015 16:58 #36790
by minaton
also its Stock firmware thatcame on the DEVO 10
- SirDomsen
11 Aug 2015 20:16 #36802
by SirDomsen
VERIFY wiring of the motors (Motor 1 = left front for example and so on), propeller mount (cw, ccw) and if the motors running in the right direction. 90 percent of all issues can be solved by doing this. I by myself did a mistake here, too like almost every multicopter pilots have.
Greetz
Domsen
Greetz
Domsen
- minaton
12 Aug 2015 10:11 #36822
by minaton
Already did that. was very first thing i check
- SirDomsen
12 Aug 2015 10:37 #36823
by SirDomsen
did you accidently select 'heli' while setting up your tx? Then the Tx mixes some channels together for giving the pitch to the Heli. In the GUI only throttle channel should move if you flip the throttle stick up and down...
- minaton
12 Aug 2015 11:30 #36825
by minaton
no i have it set as airplane. i like to try find someone who has a devo 10 and users a tricopter so i can get the setting from them just as a staring point
- SirDomsen
12 Aug 2015 16:23 #36827
by SirDomsen
I fly only Quadcopters, but shouldn't they be programmed the same way like tricopters concerning the tx?
Perhabs a Tricopter Pilot can tell us
SirDomsen
SirDomsen
- magic_marty
12 Aug 2015 17:27 #36828
by magic_marty
Replied by magic_marty on topic Tricopter flips when throttle only is used devo10
Make sure you have the servo and rear motor plugged into the correct outputs on the KK board...
- SirDomsen
14 Aug 2015 07:50 #36869
by SirDomsen
Another thing could have happened: did you turn your fc by any degrees in yaw direction? This happened to me with my cc3d quadro yesterday, an i had to remeber you with your issue. I turned the cc3d 90 degrees right but forgot to setup this. Caused in two damaged props and one spinner, because it flipped on the ground at about half throttle
- minaton
14 Aug 2015 10:00 #36871
by minaton
fc ? whats this mean?
14 Aug 2015 10:19 #36872
Replied by FDR on topic Tricopter flips when throttle only is used devo10
Flight controller
Time to create page: 0.108 seconds
Stock Firmware Help
- Tricopter flips when throttle only is used devo10
