v5 not loading
- Lefty
- SirDomsen
19 Jul 2016 08:48 #51876
by SirDomsen
Replied by SirDomsen on topic v5 not loading
You don't tell much about your Problem. Which Devo? Which OS? Which version of Deviation?
Did you install the drivers? Does the computer recognize a (unknown) device?
- Thomas.Heiss
19 Jul 2016 09:37 - 19 Jul 2016 09:37 #51878
by Thomas.Heiss
Replied by Thomas.Heiss on topic v5 not loading
Top left "Available DFU devices" box seems to be empty.
It actually needs to show the Devo device.
Did you hit "EXT" on power on so your devo transmitter shows the firmware upgrade icon in display?
It actually is the "Upgrade" button which needs to be greyed out.
Thomas
Thomas
Last edit: 19 Jul 2016 09:37 by Thomas.Heiss.
- aMax
19 Jul 2016 09:42 - 19 Jul 2016 09:43 #51879
by aMax
Most probably your TX is not in DFU mode. (use EXT button at power on).
There is no STM device shown. Windows10 user?
Thomas beat me to it.
Replied by aMax on topic v5 not loading
Last edit: 19 Jul 2016 09:43 by aMax.
- Lefty
19 Jul 2016 11:40 #51886
by Lefty
Replied by Lefty on topic v5 not loading
Hi, Thanks for the response
I am using Windows 10 OS and version 5.0 of deviation firmware, I did use the ext button to prepare for the update and it reflected this on the tx screen Devo 10.
I look forward to your replies Thank you.
John
John
19 Jul 2016 13:54 #51889
Replied by mwm on topic v5 not loading
As noted, the empty "Available DFU devices" box is the issue. Your device isn't connecting properly. Since you are using Windows, you'll need to install the appropriate driver. The driver and an installation tool are available from the downloads area.
If you've installed the driver, then check the device manager on your system to see if the device is working.
- Lefty
21 Jul 2016 07:21 #51955
by Lefty
Thanks all for the replies, I have not responded as I am still battling with this.
I have changed computers and OS now trying windows 7 I have downloaded drivers and upgrade tool - working my way through various releases of it.
I just wanted to touch base and thank all for the advice. I will reply when I have solved this.
John
John
21 Jul 2016 12:59 #51957
If you're installing OS's for this, I'd recommend installing Linux and using the Deviation USB installer. Linux already has working drivers, so all those issues just go away.
Time to create page: 0.108 seconds
Stock Firmware Help
- v5 not loading
