v120 setup help needed
- Birdman
24 Dec 2013 22:53 - 24 Dec 2013 23:20 #16988
by Birdman
v120 setup help needed was created by Birdman
merry xmas to all
help needed please
trying to setup my new v120d02s v2
easy to do with stock firmware
got model ini from conf thread
[channel1]
template=expo_dr
[mixer]
src=ELE
dest=Ch1
scalar=70
curvetype=expo
points=30,30
i do not understand the following:
"points=30,30"
TIA
Bm
edit: shame the first post of config thread doesn't contain any info on how to use ini
i'll try 30% pos expo
help needed please
[channel1]
template=expo_dr
[mixer]
src=ELE
dest=Ch1
scalar=70
curvetype=expo
points=30,30
"points=30,30"
TIA
Bm
Last edit: 24 Dec 2013 23:20 by Birdman.
- Birdman
25 Dec 2013 02:42 - 25 Dec 2013 02:46 #16989
by Birdman
Replied by Birdman on topic v120 setup help needed
i think people forget we are not all programmers
thanks anyway guys
turns out the 120 is a dud anyway
thanks anyway guys
Last edit: 25 Dec 2013 02:46 by Birdman.
- Birdman
25 Dec 2013 03:08 - 25 Dec 2013 03:38 #16990
by Birdman
Just bound v120 to devo7 it came with and it flies just fine.
When using Devo8s with Deviation:
servos seem eratic, one in particular
heli does not lift off
Bm
edit:
Have done standard and advanced setup, same results.
Have mini genius cp, trex setup and work fine.
This is first setup since upgrading to beta 3.1
Bm
edit:
Last edit: 25 Dec 2013 03:38 by Birdman.
25 Dec 2013 07:02 #16991
Replied by FDR on topic v120 setup help needed
To be able to help, please post the whole model config.
The "30,30" means a symmetric 30% expo value...
- HappyHarry
25 Dec 2013 14:48 #17006
by HappyHarry
Replied by HappyHarry on topic v120 setup help needed
i posted a working config for the v120d02s in this post here >>
deviationtx.com/forum/model-configs/2428...er-for-devo-10#16392
it's for a 7e but you should be able to work from it to set up your own tx
phil
phil
Time to create page: 0.100 seconds
- v120 setup help needed
