DEVO 12E
- schwarzsurfer
- netnerd
17 Mar 2015 21:10 #29789
by netnerd
Replied by netnerd on topic DEVO 12E
Awesome job, PB. I think you're right about B0 considering the similarities between the two boards (seems to be the only unused ADC pin). Since PB9 can act as USART, I'd imagine it's related to debugging and possibly just moved from the DEVO 10 (I'd imagine that the similar trace below it connects to B8).
- schwarzsurfer
- warrenhdavis
03 Apr 2015 18:35 #30759
by warrenhdavis
Replied by warrenhdavis on topic DEVO 12E
I uploaded the test build a couple of times but my F12E would not turn on after leaving DFU mode each time. I was able to re-enter DFU mode again after unplugging the battery and put back the stock 15A firmware. I would love to get this going since I want to use a Frysky D4R-II with it.
- schwarzsurfer
- dc59
- dlawso
- Dj_Garfield
15 Jul 2015 17:33 #35486
by Dj_Garfield
Replied by Dj_Garfield on topic DEVO 12E
The Same for me , I tested with the 2 FW posted , but the first made a Pixelised Black Screen , and the second one Nothing on the screen and nothing on the Rx , the light stay blinking on my Multirotor
Gone back to original FW
16 Jul 2015 16:09 #35530
Replied by PhracturedBlue on topic DEVO 12E
I don't understand.
Did you read this post:
deviationtx.com/forum/3-feedback-questio...devo-12e-white#35053
That version will not show anything on the screen and it won't work with your model. It should let you trun on/off with the power switch, and it should enter USB mode (plug the tx into your pc, and turn it on while holding no buttons...your PC should detect it)
- Dj_Garfield
19 Jul 2015 11:26 - 19 Jul 2015 11:29 #35651
by Dj_Garfield
Yes I read the post , and knew that it could works but W/O displaying anything .. but I wrote that the Radio didn't link to my Reciever on the Multirotor ... so I dont works on my radio
I just wanted to give you a report , and if you need some other information , just ask me
I will be happy to help you if you ( or somebody else ) plan to work on it .
I can't believe that we are not enough 12E users asking for a mod for this Radio that motivate some good developers
After that if this is Impossible Mission to do it with specialy the 12E Radio , I understand the fact that we have to stay with Stock Firmware
Last edit: 19 Jul 2015 11:29 by Dj_Garfield.
- marco899
- TomPeer
- marco899
- nwoodschris
13 Feb 2016 09:42 #43084
Replied by FDR on topic DEVO 12E
There is no wireless body boxing in the DEVO transmitters.
There is only a wireless model config transfer you can use to have the same model config in both transmitters in order to use boddy boxing.
And no deviation doesn't have the wireless model config transfer, but it doesn't have to use the same model config on both transmitters either...
- darthnugget
27 Feb 2016 03:53 #43750
by darthnugget
Replied by darthnugget on topic DEVO 12E
www.deviationtx.com/forum/how-to/5471-ho...with-deviation#43744
This is how I was able to load my F12E, and I have read that the F7 might work the same way.
- sriniak
23 Jun 2016 21:20 #51011
by sriniak
Replied by sriniak on topic DEVO 12E
Any Update? I bought DEVO 12E thinking it is similar to DEVO 10 with extra channels and can load DeviationTx (my bad for not checking the supported models!!) Appreciate if someone can confirm working and a video if possible for the configuration and settings.
- robca
29 Dec 2016 22:50 #57345
by robca
Just in case you have not seen this yet: www.deviationtx.com/forum/6-general-disc...ber-sale-devo-12e-75
There are nightly builds now
Replied by robca on topic DEVO 12E
sriniak wrote: Any Update? I bought DEVO 12E thinking it is similar to DEVO 10 with extra channels and can load DeviationTx (my bad for not checking the supported models!!) Appreciate if someone can confirm working and a video if possible for the configuration and settings.
- ando1
18 Jan 2017 15:15 #58120
by ando1
I just loaded the latest nightly build on my new 12E and it works fine. One thing to note, if you are installing the 4in1 module, use the picture for the 10E for where to solder the wires.
Andy
Replied by ando1 on topic DEVO 12E
Andy
Time to create page: 1.111 seconds
- DEVO 12E
