- joeblack
19 Oct 2016 08:08 #55128
by joeblack
Replied by joeblack on topic 3in1 / 4in1 RF module
Would also like to buy a 4in1 module for my DEVO10.
I´m from Austria/Europe and TAOBAO doesn´t ship there.
My Question:
is there a way to buy such a 4in1 Modul for me now or do i have to wait until it´s available at Banggood or Aliexpress.....
thanks in advance
joe
My Question:
thanks in advance
joe
- ajtank
19 Oct 2016 08:41 #55131
by ajtank
Replied by ajtank on topic 3in1 / 4in1 RF module
It seems the other fellows used an agent called Taobao Focus to buy the module from China.
- DaveyP
19 Oct 2016 10:57 #55132
by DaveyP
Replied by DaveyP on topic 3in1 / 4in1 RF module
Check my post (and others)
www.deviationtx.com/forum/7-development/...dule?start=860#54118
As ajtank suggests, use Taobao Focus to do the transaction for you.. they even send pictures of the item so you can check it before they dispatch.
- epilot
- Elmtree
19 Oct 2016 13:59 #55143
by Elmtree
Replied by Elmtree on topic 3in1 / 4in1 RF module
I installed my 4in1 module, but I'm not sure if I need to enable the amps in the hardware.ini. Do I?
- raketemensch
19 Oct 2016 14:32 #55147
by raketemensch
Is this the new drop-in module? If so, I guess it needs a little soldering on the 7e, but I haven't seen a guide for it yet. I'd love to pick this up, but I'm not sure if I'd be capable of installing it yet.
Replied by raketemensch on topic 3in1 / 4in1 RF module
epilot wrote: The module is available on Banggood now.
4in1 module
- victzh
19 Oct 2016 15:02 #55148
by victzh
Replied by victzh on topic 3in1 / 4in1 RF module
This "drop-in" module still requires soldering even in Devo 10. The small 3 position connection point should be soldered as shown on one of the pictures on Banggood.
- ds864
19 Oct 2016 15:04 - 19 Oct 2016 15:13 #55149
by ds864
Replied by ds864 on topic 3in1 / 4in1 RF module
Yes me too. The picture on the site looks like the Devo 10.
I've been looking at this ( www.hacksmods.com/category/devo/ ) to see how to do each module but the 4 in 1 sounds like a better move. I just need some step-by-step instructions for the Devo 7e if this is compatible?
Do you have to remove the existing module? Will this then have a better range than the stock module?
Last edit: 19 Oct 2016 15:13 by ds864.
19 Oct 2016 15:28 #55150
Replied by hexfet on topic 3in1 / 4in1 RF module
Yes, enable the pa for all.Elmtree wrote: I installed my 4in1 module, but I'm not sure if I need to enable the amps in the hardware.ini. Do I?
- Fer
19 Oct 2016 15:44 - 19 Oct 2016 15:44 #55151
by Fer
Replied by Fer on topic 3in1 / 4in1 RF module
At last. It is available in Banggood. Of course i have already purchased mine (at a price of 55 euros with all the commisions and fees for the agent), but it is good to know that banggood now offers this module.
Until a better option appears, that solves the LNA problem with a hardware fix, this is the best option so far for DEVO 10 users.
Last edit: 19 Oct 2016 15:44 by Fer.
- victzh
19 Oct 2016 15:46 #55152
by victzh
@ds864 - for installing 4-in-1 you need to remove existing module because 4-in-1 has CYRF6936 as well. It will have better range because it has PA - Power Amplifier - and though stock module has it also it is artificially limited.
- ajtank
19 Oct 2016 15:55 #55154
by ajtank
This module is mounted on a carrier board which is designed specifically for Devo 10. For Devo 7E you need to get the module without the carrier board
For 7E it seems the 3-in-1 is more appropriate.
4in1 module
- victzh
19 Oct 2016 16:05 #55155
by victzh
3-in-1 still has problems with protocols using receiving part of RF - either telemetry or with auto-acknowledge. Today 4-in-1 is the best module to install despite higher cost. Devo 10 specific module is also suitable for 7E, there are instructions for this here (thanks, HappyHarry)
www.deviationtx.com/forum/how-to/5955-7e...-4in1?start=20#50816
- HappyHarry
19 Oct 2016 16:08 #55156
by HappyHarry
devo 4in1 fitting guide to the 7e is availabe here >> www.deviationtx.com/forum/how-to/5955-7e...he-devo-version-4in1
Replied by HappyHarry on topic 3in1 / 4in1 RF module
ds864 wrote: Yes me too. The picture on the site looks like the Devo 10.
19 Oct 2016 16:25 - 06 Mar 2017 06:04 #55157
Replied by vlad_vy on topic 3in1 / 4in1 RF module
Summary of module connections (3 wires) (Devo 6, Devo 7e, Devo 10, Devo 8, Devo F12E, Devo 12):
7105 = TMS pad (A13)
2500 = TCK pad (A14)
2401 = ???
4in1 module pinout
Devo6
2401 = C10
hardware.ini
Devo7e
2401 = A15
hardware.ini
Devo10
2401 = B7
hardware.ini
Devo8, Devo F12E (PCB looks slightly different but MCU and pin are the same)
2401 = B3
hardware.ini
Devo12
2401 = B3
hardware.ini
2401 = ???
4in1 module pinout
Devo6
2401 = C10
hardware.ini
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
[modules]
enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = C10
has_pa-nrf24l01 = 1
; enable-multimod = A13Devo7e
2401 = A15
hardware.ini
;enable-haptic=1
;extra-switches=
;extra-buttons=
[modules]
has_pa-cyrf6936 = 0
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A15
has_pa-nrf24l01 = 1
; enable-multimod = A13Devo10
2401 = B7
hardware.ini
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B7
has_pa-nrf24l01 = 1
; enable-multimod = A13Devo8, Devo F12E (PCB looks slightly different but MCU and pin are the same)
2401 = B3
hardware.ini
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B3
has_pa-nrf24l01 = 1
; enable-multimod = A13Devo12
2401 = B3
hardware.ini
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
Last edit: 06 Mar 2017 06:04 by vlad_vy.
- ds864
20 Oct 2016 07:37 #55181
by ds864
Thanks for the help on this it still looks like a lot of work fitting the 4-in-1 into a 7e. I kind of like the idea of the 3-in-1 as I won't be touching the original module. This way if it all goes wrong I still have that module working (no worse off). But what are the issues with the 3-in-1 you mention?
20 Oct 2016 08:48 #55182
I'm not sure, but it looks like 3in1 has problem with LNA for A7105 and nRF24L01 chips.
- justyn07
20 Oct 2016 13:59 #55190
by justyn07
Replied by justyn07 on topic 3in1 / 4in1 RF module
i just order a 4 in 1 module from banggood and i never done the hardware ini. do you just copy paste the ini.
20 Oct 2016 14:25 #55191
You need UNIX style editor to edit *.ini files. For example, "Notepad+".
- justyn07
20 Oct 2016 15:24 #55195
by justyn07
thank you. i have notepad+.
Time to create page: 0.395 seconds
- Devo 12s 3in1 / 4in1 RF module neat installation.
