- ajtank
raketemensch wrote:
epilot wrote: The module is available on Banggood now.
4in1 module
Is this the new drop-in module? If so, I guess it needs a little soldering on the 7e, but I haven't seen a guide for it yet. I'd love to pick this up, but I'm not sure if I'd be capable of installing it yet.
This module is mounted on a carrier board which is designed specifically for Devo 10. For Devo 7E you need to get the module without the carrier board
For 7E it seems the 3-in-1 is more appropriate.
- victzh
- HappyHarry
ds864 wrote: Yes me too. The picture on the site looks like the Devo 10.
I've been looking at this ( www.hacksmods.com/category/devo/ ) to see how to do each module but the 4 in 1 sounds like a better move. I just need some step-by-step instructions for the Devo 7e if this is compatible?
Do you have to remove the existing module? Will this then have a better range than the stock module?
devo 4in1 fitting guide to the 7e is availabe here >> www.deviationtx.com/forum/how-to/5955-7e...he-devo-version-4in1
7105 = TMS pad (A13)
2500 = TCK pad (A14)
2401 = ???
4in1 module pinout
Devo6
2401 = C10
hardware.ini
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
[modules]
enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = C10
has_pa-nrf24l01 = 1
; enable-multimod = A13
Devo7e
2401 = A15
hardware.ini
;enable-haptic=1
;extra-switches=
;extra-buttons=
[modules]
has_pa-cyrf6936 = 0
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A15
has_pa-nrf24l01 = 1
Devo10
2401 = B7
hardware.ini
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B7
has_pa-nrf24l01 = 1
Devo8, Devo F12E (PCB looks slightly different but MCU and pin are the same)
2401 = B3
hardware.ini
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B3
has_pa-nrf24l01 = 1
Devo12
2401 = B3
hardware.ini
;enable-haptic=1
;extra-switches=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
- ds864
- justyn07
- justyn07
- ako
4in1 module
Hmm... what about the antenna track from the solder point of the bare module to the UFL connector? Doesn't it affect the signal quality?
One could consider cutting the trace and soldering a UFL connector directly to the three points at the bare module. Is the stock antenna cable long enough to reach that point? I don't want to open my Devo 10 to check it.
I would consider buying this new module for my Devo 10 and removing the bare 4in1 and using that one in my AT9 when everything is ready.
- victzh
But people report reasonable power output from the module, so maybe we don't understand something.
- HappyHarry
- victzh
- BirdBarber
- Hummingbird Assassin
- ds864
Whilst I'm at it I'm going to cut off the top of the existing aerial and put on a screw fitting too. I may even be tempted to go for the range mod if I can get the shield off. I also have some 3 position switches coming for the ultimate Devo 7e.
NRF24L01 : www.aliexpress.com/item/2-4G-NRF24L01-PA....13010608.0.0.5UhMdP
A7105: www.aliexpress.com/item/A7105-RFIC-500m-....13010608.0.0.UrHGw3
- C0ckpitvue 777
- C0ckpitvue 777
- epilot
- HappyHarry
- C0ckpitvue 777
- Devo 12s 3in1 / 4in1 RF module neat installation.
