Super CP
12 Mar 2013 02:16 - 12 Mar 2013 18:31 #7649 by coreire
Super CP was created by coreire
Finished my config for the Super CP and said I'd share it in case it's useful to someone.
I tried to keep it close to the standard setup in the heli's manual.
Throttle hold is controlled by RUDD D/R, cuts throttle but does not affect pitch.
There are 3 gyro settings, which are controlled by the Mix switch.
Mix0 - 75%
Mix1 - 50%
Mix2 - 40%
There are 3 flight modes, controlled by the FMOD switch.
FMOD 0 = Standard flight
70% rates on aileron and elevator channels
-20 to +50 pitch curve
FMOD 1 = Stunt mode 1
-50 to +50 pitch curve
V throttle curve - 100%, 75%, 100%
FMOD 2 = Stunt mode 2
100% rates on aileron and elevator channels
AILE D/R will give 100% throttle output, regardless of the position of FMOD.
Last edit: 12 Mar 2013 18:31 by coreire.
12 Mar 2013 05:38 #7653 by sbstnp
Replied by sbstnp on topic Super CP
You forgot to attach the file.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
12 Mar 2013 09:57 #7659 by blackmoon
Replied by blackmoon on topic Super CP
What do you mean by "Idle up is controlled by AILE D/R." ?
Stunt is just another word for Idle Up, that is already mapped to FMOD.
So what do you control with AIL D/R ?
Is it pitch curves set to +-100 vs +-50 in FMOD ?
And yes the file would be appreciated :p
Thanks.
12 Mar 2013 18:45 - 12 Mar 2013 18:46 #7660 by coreire
Replied by coreire on topic Super CP
blackmoon wrote: What do you mean by "Idle up is controlled by AILE D/R." ?
Thanks.
Oops, thought I attached the file. I've attached it now.
That probably wasn't the best way to describe what Aile D/R does, I've edited it. It gives you 100% throttle output.
The pitch curves are +-50. I've set them that way for myself as I'm just learning 3d and doing so indoors.
You can change them easily if you wish by changing points 1 and 3 to -100 and +100, or if you'd like me to make any changes to suit how you like to fly let me know and I'll make you a separate file.
Last edit: 12 Mar 2013 18:46 by coreire.
13 Mar 2013 00:13 - 13 Mar 2013 00:20 #7664 by blackmoon
I'm getting around quite well with the model files so I'll do the modifications myself, I'm just lazy and prefer to modify than doing it from scratch :p
Thanks for the file.
Edit: You have this mixer, repeated in the file (I don't think it would do any arm, but one never know) :
[mixer]
src=AIL DR1
dest=Ch3
switch=AIL DR1
usetrim=0
curvetype=expo
points=0,0
Last edit: 13 Mar 2013 00:20 by blackmoon.
13 Mar 2013 01:31 - 13 Mar 2013 01:32 #7667 by coreire
blackmoon wrote: I'm getting around quite well with the model files so I'll do the modifications myself, I'm just lazy and prefer to modify than doing it from scratch :p
[mixer]
src=AIL DR1
dest=Ch3
switch=AIL DR1
usetrim=0
curvetype=expo
points=0,0
Yup, its repeated because the first was an override for the standard throttle curve. Then the FMOD 1 and 2 curves were added at a later stage and I readded it after them instead of moving everything back a page. It won't causes any issues, the first instance of it just becomes redundant.
Last edit: 13 Mar 2013 01:32 by coreire.
13 Mar 2013 13:08 - 13 Mar 2013 13:10 #7680 by Mullson
Replied by Mullson on topic Super CP
coreire wrote: There are 3 gyro settings, which are controlled by the Mix switch.
Mix0 - 75%
Mix1 - 50%
Mix2 - 40%
Is this by choice If so why? Isn't the translation from WK startup settings like this:
Mix0 - 50%
Mix1 - 40%
Mix2 - 0%
Don't you want to be able to turn of HH?
Thanks for the ini.
Last edit: 13 Mar 2013 13:10 by Mullson.
13 Mar 2013 14:29 #7683 by coreire
Mix0 - 75%
Mix1 - 50%
Mix2 - 40%
Mix0 - 50%
Mix1 - 40%
Mix2 - 0%
Thanks for the ini.
I tried those settings originally when I was making the setup. The 0% setting seems to disable the gyro entirely, which isn't something I wanted in my setup.
13 Mar 2013 14:56 #7685 by Mullson
How is your bind proses, how do you bind and rebind?
Mine inited and I cold control everything. But when I try to bind or reinit again It just dont work? the id is reset. This is whit 7E.
13 Mar 2013 15:20 #7686 by coreire
Mullson wrote: How is your bind proses, how do you bind and rebind?
I just connect battery, power on tx, put heli on level surface. I haven't been using rebind function so can't comment on that. I don't have the tx near me now but I don't think I set a fixed ID in that setup
14 Mar 2013 00:15 - 14 Mar 2013 00:16 #7719 by Mullson
I manage to bind it to a fixed id now. thanks for yor note.
Bind blug in then out. Restart Tx and rx. Let tx bind with heli on a leveld surface. Until the rx twitches. Then go in to model setup and deside a bind code 123123"BIND". and its finn
Last edit: 14 Mar 2013 00:16 by Mullson.
14 Mar 2013 00:25 #7720 by Mullson
I was testing new mini dene plugs on a few batteries so I was distracted and forgot to let tha gyro initalise.
The mini dens are no wonder and gives 0.1g to the outers. But I love them for the connectability.
21 Mar 2013 02:14 - 21 Mar 2013 05:39 #7937 by CPpilot
Replied by CPpilot on topic Super CP
I am new to Deviation. Fortunately, I have done everything right to my Devo7E last evening and it's in good shape now. Where can I get a tuned scp config.? How can I upload it to my tx? There are few folders under the root drive.
Thanks :cheer:
Last edit: 21 Mar 2013 05:39 by CPpilot.
21 Mar 2013 07:58 #7946 by domcars0
Replied by domcars0 on topic Super CP
You can pick up the model7.ini given by coreire at the beginning of this topics and put this file in the models/ directory of the USB Filesystem of your Devo7e ... (change model number modelX.ini if needed)
21 Mar 2013 08:18 #7947 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Super CP
Also check where the Throttle Hold is assigned, as the 7E doesn't have a Rudder D/R switch; not sure if it "redeploys gracefully" or not.
And there's only FMOD0 and FMOD1, but that shouldn't be an issue. Also check gyro assignment.
21 Mar 2013 11:42 #7949 by CPpilot
Thank you. I will work on it, but telemetry screen showed "Telemetry is not supported". How do I activate it?
Thanks.
21 Mar 2013 13:19 #7955 by vlad_vy
Replied by vlad_vy on topic Super CP
If protocol has telemetry supported, press protocol button and swith on telemetry.
22 Mar 2013 09:19 #7995 by CPpilot
How about *.elf files? Do I need to copy those under the root drive?
Thanks,
22 Mar 2013 09:38 #7996 by vlad_vy
No, it's for debug purpose (send along with errors.txt).
27 Mar 2013 23:23 #8162 by JJ1984
Replied by JJ1984 on topic Super CP
Just a quicky will this file work with a Mini CP
Time to create page: 0.247 seconds
