Eachine or JJRC H8 mini ?
12 Sep 2015 15:52 #37686 by retrobits
Replied by retrobits on topic Eachine or JJRC H8 mini ?
I have the X9 and like it, although not quite as much as the H8 mini. X9 strong points are great vertical lift and stability. It does have good pitch for attacking wind. Maybe due to flex body design or canopy its blown about a little more than H8. Yaw is adequate, but a little slow for my taste. To me its a great little machine, but not quite the beast of awesomeness that H8 mini is.
12 Sep 2015 23:15 - 12 Sep 2015 23:50 #37702 by Richard96816
Replied by Richard96816 on topic Eachine or JJRC H8 mini ?
retrobits wrote: I have the X9 and like it, although not quite as much as the H8 mini. X9 strong points are great vertical lift and stability. It does have good pitch for attacking wind. Maybe due to flex body design or canopy its blown about a little more than H8. Yaw is adequate, but a little slow for my taste. To me its a great little machine, but not quite the beast of awesomeness that H8 mini is.
I'm growing to like the X9 more. It's a wonderful outdoor flier. It's a touch bigger than the H8 which seems to help. Also heavier, 12 vs. 16 grams. It seems more balanced to me -- probably a sign that my model.ini for the H8 needs work. The H8 tends to slide sometimes on turns. (I wonder how the H8 would fly with X9's larger props on it.)
The X9 may flex some, not sure. But whatever it is I like the end result. Good training quad. Small inputs cause it to tilt and move and telegraph its actions. It fights gusty winds better than my bigger quads. Though my fingers get more of a workout while doing it. It's extremely quick. So many times I would have crashed a lesser quad, the X9 powers out of difficult situations. Plenty of power all the way to end of a charge. That's cool.
Edit: They both weight 12 grams. Had a battery in the X9. :-/
Last edit: 12 Sep 2015 23:50 by Richard96816.
14 Sep 2015 11:29 #37754 by Fernandez
Replied by Fernandez on topic Eachine or JJRC H8 mini ?
Just to report that the Eachine H8 flies really well with my devo 7e! Using the Model17.ini, posted in this threat.
Thanks guys!
20 Sep 2015 21:18 - 20 Sep 2015 21:18 #37910 by NIcolas31417
Replied by NIcolas31417 on topic Eachine or JJRC H8 mini ?
Works pretty well here too, a big THANKS to all of you guys.
However, i have a little concern, i cant bind my frsky receivers anymore since i flashed the new deviation firmware (deviation-devo7e-v4.0.1-ee51ea2 )
i used to use a nightly build, in order to control frsky, is there a way to get them both ?
Last edit: 20 Sep 2015 21:18 by NIcolas31417.
  • BirdBarber
  • BirdBarber's Avatar
  • Hummingbird Assassin
26 Sep 2015 19:51 #38091 by BirdBarber
Replied by BirdBarber on topic Eachine or JJRC H8 mini ?
Is there a Nightly Build with the Bayang protocol for the 8S yet, or an ETA when there might be one?
27 Sep 2015 14:36 #38110 by Sicon
Replied by Sicon on topic Eachine or JJRC H8 mini ?
Hello! Do you know how and if is possibile to calibrate the H8 mini with a devo 7e? With its controller is just put the right and left sticks in lower-right position but it doesn't work with the devo and I need to calibrate it.
Thank You!
27 Sep 2015 19:10 #38121 by NIcolas31417
yes it is possible, i did it. Actually u shouldnt try to calibrate the eachine, but the devo, do u know the way to do this?
27 Sep 2015 19:11 #38122 by retrobits
The model ini for the 7e posted earlier in this thread is for the 7e with 3x2 switch mod. The two 3-pos switches control the rate. Switches in default position indicate lowest rate, and at least on my H8 mini, it does not calibrate in the lowest rate. By setting both switches in the middle, the calibration works properly. So, if you don't have the 3x2 switch mod, you would need to edit the model.ini file to adjust default rate on both sticks or assign another switch to change rates.
02 Oct 2015 14:42 #38355 by retrobits
Looks like hexfet's changes are in the latest nightly. deviation-devo10-v4.0.1-2cde795.zip , I haven't tested yet, plan to later today
THANK YOU HEXFET!
13 Oct 2015 19:37 #38776 by DodgeTHIS
Replied by DodgeTHIS on topic Eachine or JJRC H8 mini ?
Hi all, so I have the latest nightly of deviation installed and I took Phillycopter8 ini file and loaded the model onto the Devo 7e but I cant get it to bind, how do I diagnose the problem? THis is the first time I use the 7e but experienced with R/C.
13 Oct 2015 19:41 #38777 by NIcolas31417
do u have soldered the module Nrf24l01 ?
13 Oct 2015 19:46 #38778 by DodgeTHIS
oh, how silly of me, no I have not. Can I extract it from a H8 TX or do I need to buy one?
13 Oct 2015 23:56 #38783 by retrobits
I don't know about harvesting from H8 mini controller, but if you are going to mod your 7e, you should just install the NRF because:
1. clear & documented instructions with support already built into devation firmware
2. you would get a whole bunch of other & future protocols enabled in the bargain.
this is the one I installed -- works like gangbusters
www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
14 Oct 2015 05:00 #38793 by Durete
Replied by Durete on topic Eachine or JJRC H8 mini ?
DodgeTHIS wrote: oh, how silly of me, no I have not. Can I extract it from a H8 TX or do I need to buy one?
You can't use the H8 TX module because it's an XN297 based module.
You need to install a real nRF24L01+ module.
Retrobit's advise is right :)
24 Oct 2015 16:49 #39169 by kolergy
Replied by kolergy on topic Eachine or JJRC H8 mini ?
I installed the nightly build deviation-devo7e-v4.0.1-6b6e0f4
then the dfu from deviation-devo7e-v4.0.1-fb23eb7 (the hexfest combo) for the H8
copied the protocols
And the H8 model .ini
and the NRF24L01+
I'm not able to bind
Is there a way to debug & try to understand why it is not binding ?
Cheers
27 Oct 2015 02:47 #39227 by hexfet
Replied by hexfet on topic Eachine or JJRC H8 mini ?
There's not much to check as this protocol just sends blindly. Does your tx work with other nRF24L01 models? No '*' in front of the protocol name?
  • BirdBarber
27 Oct 2015 03:52 #39229 by BirdBarber
Any news on when this protocol might be available for the 8S?
27 Oct 2015 08:06 #39234 by kolergy
The remote is brand new and i have not tried it with anything else, I have an Hubsan that I can try it with. I'l post it once i tried
Is there any difference with the + and the non + model of the NRF module ?
Thanks for the help
27 Oct 2015 08:17 #39235 by Durete
BirdBarber wrote: Any news on when this protocol might be available for the 8S?
This protocol is merged into the main branch, so should be available for all Devo models in last nighlies.
27 Oct 2015 08:20 #39236 by Durete
kolergy wrote: The remote is brand new and i have not tried it with anything else, I have an Hubsan that I can try it with. I'l post it once i tried
Thanks for the help
The Hubsan protocol is using a different transceiver (A7105).
Do you have really installed an nRF24L01 RF transceiver?
About the differences between + and non + nRF transceivers, the main difference is the lowest datarate possible.
For this protocol should not be a problem to use a non + transceiver.
SymaX protocol doesn't work with a non + transceiver because use a lower datarate non compatible with non plus RF transceivers.
Time to create page: 0.124 seconds
