Eachine or JJRC H8 mini ?
02 Jun 2015 12:48 #33358 by mrbeefy
Eachine or JJRC H8 mini ? was created by mrbeefy
will this work with the deviation firmware?
11 Jul 2015 21:23 #35343 by Richard96816
Replied by Richard96816 on topic Eachine or JJRC H8 mini ?
The H8 mini would be an amazing flier with a little Deviation.
Tone down the top yaw rate, and it's steep pitch will fight some hefty winds. It's got everything -- just needs a little polish.
Great indoor/outdoor flier!
11 Jul 2015 23:57 #35345 by Durete
Replied by Durete on topic Eachine or JJRC H8 mini ?
And also this protocol is compatible with the BayangToys X6, X7, X9 and the new JJRC JJ850 :)
I ordered a new X9 and will capture SPI traces when receive, in case nobody capture before me :pinch:
18 Jul 2015 11:39 - 18 Jul 2015 11:57 #35603 by S.Giles
Replied by S.Giles on topic Eachine or JJRC H8 mini ?
I would also love to see the H8 Deviated. With a view to helping that process along, I have posted a capture of the bind process here .
I'll keep my transmitter wired-up in case more captures are needed at some point.
Last edit: 18 Jul 2015 11:57 by S.Giles.
18 Jul 2015 20:29 #35631 by Richard96816
S.Giles wrote: I would also love to see the H8 Deviated. With a view to helping that process along, I have posted a capture of the bind process here .
Please continue! Expect the H8 mini to be one of the very best nano indoor/outdoor fliers once Deviated.
It's awesomeness awaits.
18 Jul 2015 21:16 #35634 by hexfet
Replied by hexfet on topic Eachine or JJRC H8 mini ?
Nothing complicated in the binding. Need captures for the channels, trims, and special functions.
- The data phase address and rf channels (4) are sent in the bind packet
- Last packet byte is checksum - just the sum of packet bytes
- First packet byte a4 for bind, a5 for data phase?
Don't want to monopolize the fun of implementation...who wants to jump in?
19 Jul 2015 14:32 #35656 by Durete
I can help in some days when receive the BayangToys X9.
I think this protocol will be very expected, since the Eachine/JJRC H8 mini, BayangToys X6, X7, X9, JJRC JJ850 and maybe more models, are on this protocol.
19 Jul 2015 17:28 #35658 by S.Giles
I have uploaded a few more captures in the same place and will add more shortly.
I'm trying to figure out the subtleties of the H8's special functions, and learning to speak fluent Chinglish in the process. :-)
19 Jul 2015 23:59 #35659 by dc59
20 Jul 2015 01:53 - 20 Jul 2015 01:54 #35661 by hexfet
dc59 wrote: I also captured H8 mini SPI data,hope it could help.
Yes, that's helpful thanks. The Headless Button capture seems to have two buttons in it - please clarify how you made the capture? The first bit change is little over 4.5 seconds after the start of the capture, with an additional bit asserted at about 7 seconds.
Last edit: 20 Jul 2015 01:54 by hexfet.
20 Jul 2015 01:54 #35662 by hexfet
What should be the name of this protocol?
20 Jul 2015 05:10 #35663 by Durete
I vote for "BayangToys" because is the older model using this protocol :P
20 Jul 2015 09:20 #35665 by czajunia
Replied by czajunia on topic Eachine or JJRC H8 mini ?
Durete wrote: I vote for "BayangToys" because is the older model using this protocol :P
Maybe 'BayangT' then :)
20 Jul 2015 10:27 #35666 by dc59
Replied by dc59 on topic Eachine or JJRC H8 mini ?
Thanks Hexfet.
Maybe I pressed other button when I captured headless function, I will capture headless signal again and will upload it once I finish job.
20 Jul 2015 12:32 #35669 by dc59
Hi hexfet,
I captured headless function again and uploaded,
www.mediafire.com/download/1f8qtkegesqdmnd/H8mini-Headless.zip
after bind to H8 mini, I applied a little throttle and pressed headless button then stop capture.
20 Jul 2015 19:59 #35699 by hexfet
dc59 wrote: after bind to H8 mini, I applied a little throttle and pressed headless button then stop capture.
I do see just one button in this capture. Is there possibly a second function that is enabled by holding the button down for a long time, like a "long press"?
20 Jul 2015 20:09 #35700 by hexfet
I've uploaded a Test Build for the 7e. Let me know if other builds are needed. Code is pushed to my repo.
I'll post a protocol description later - don't have my notes at the moment. Jumped straight to a random txid - if this doesn't bind we'll need to back up and try to replicate a tx that's been captured.
Headless control is on channel 9.
20 Jul 2015 21:52 #35705 by Durete
Wow! :woohoo:
Good job Hexfet :) I will test as soon I receive my new Bayang X9 (probably this week).
I only have an old Bayang X9 working on different protocol.
Short story...
Bayang Toys release the X6, X7 and X9.
After some months, they silently change the protocol in all models and added Headless and RTF. Fortunately the fantastic flying characteristics didn't change, but the old versions, don't bind with the new versions.
Some time later, were announced the Eachine/JJRC H8 using the same new protocol, and later JJRC release the JJ850.
Probably I will capture SPI on my old version and in case they are very similar (you know I'm not a programmer :blush: ), I will try to practice implementing the protocol as an option...
20 Jul 2015 23:58 #35706 by dc59
Yes, you are right ! long press headless button is "RETURN HOME" function , I captured this function at new file as below,please check it out!
www.mediafire.com/download/zaq4rzet6l9zb...8mini-ReturnHome.zip
I installed test build , but it could not bind to quad! :(
Normal procedure:
1, power on quad, quad LED slow blink.
2, power on stock TX one beep , quad LED fast blink.
3, TX second beep, quad LED on solid.
This build, quad LED always slow blink, I tried to set different ID '12345678' / '111111' / '11' and no ID,
it's all the same.
Thanks a lot!
21 Jul 2015 00:55 - 21 Jul 2015 07:37 #35709 by Richard96816
Will this protocol work with other quads?
Mine doesn't say Bayang anywhere. But they're all "H8 mini". That's the prevailing name used in the forum. Suggest that's a better name to use. Unless the Eachine H8 mini is a different bird.
Edit: Sorry, I forgot you said there were other quads that use the same protocol. I guess I was thinking if there were they must be Deviated already. I guess there are a few older models that haven't been assimilated yet ... :)
Last edit: 21 Jul 2015 07:37 by Richard96816.
Time to create page: 0.174 seconds
