Eachine or JJRC H8 mini ?
27 Oct 2015 23:00 #39265 by DodgeTHIS
Replied by DodgeTHIS on topic Eachine or JJRC H8 mini ?
Success! I now have a A7105 and a nrf24l01 both with power amps installed and now my v911 pro and eachine h8 is working great! wow what a difference with the H8, such a good quad now!
What do I change in my model ini do get the hold switch to toggle flip mode so 0 is normal flight and 1 + a direction does a flip?
  • BirdBarber
  • BirdBarber's Avatar
  • Hummingbird Assassin
28 Oct 2015 14:20 - 28 Oct 2015 14:21 #39304 by BirdBarber
Replied by BirdBarber on topic Eachine or JJRC H8 mini ?
Durete wrote: This protocol is merged into the main branch, so should be available for all Devo models in last nighlies.
Thanks, I got it loaded and works great on my 8S.
From what I can tell, channel 6 is flip, ch 9 is headless mode and ch 10 is attack my face, lol.
Last edit: 28 Oct 2015 14:21 by BirdBarber.
03 Nov 2015 22:11 - 03 Nov 2015 22:21 #39521 by eirikso
Replied by eirikso on topic Eachine or JJRC H8 mini ?
Total n00b need some help here. I received my Devo 7e today and installed the nRF24L01 module like described here: www.hacksmods.com/2013/05/nrf24l01-devo7e-pinout/
Then I installed the latest nightly build of DeviationX (deviation-devo7e-v4.0.1-583c468)
But I don't find any idiot proof instructions on how to get the 7e to bind with my Eachine H8. I have a couple of questions:
1. Where can I download an ini-file for the H8?
2. In model setup I can not find Eachine, do I choose Bayang?
3. How do I bind? Power up the H8, then choose Re-init? Or: power up the H8 and turn on the Devo 7e to let it bind during its start up process?
Well, total n00b finds the answer: it refused to bind because I hadn't calibrated the sticks. Now it binds like it should:
Choose Bayang in the Devo 7e
1 . Power up quad
2. Power up Devo 7e
3. Fly!
Last edit: 03 Nov 2015 22:21 by eirikso.
04 Nov 2015 19:29 #39562 by amrunner4
Replied by amrunner4 on topic Eachine or JJRC H8 mini ?
Does the Bayang protocol allow for a stick position to calibrate gyros?
04 Nov 2015 19:36 #39564 by NIcolas31417
Replied by NIcolas31417 on topic Eachine or JJRC H8 mini ?
it does :)
05 Nov 2015 11:25 - 05 Nov 2015 11:34 #39601 by sledgehammer1570
Replied by sledgehammer1570 on topic Eachine or JJRC H8 mini ?
Heres a little goofing around with a bayang protocol frankenquad.
H8 mini board is a killer with 7x20 motors and a light body. And deviation of course! It's not as stable as JJ1000 (v2x2) board, but it's more agressive. Very fun!
Last edit: 05 Nov 2015 11:34 by sledgehammer1570.
05 Nov 2015 21:21 #39627 by eirikso
So, the n00b has one question left: how do I configure the menus to be able to initiate acro og "headfree" with the two switches on the Devo 7e?
06 Nov 2015 10:34 #39646 by sledgehammer1570
eirikso wrote: So, the n00b has one question left: how do I configure the menus to be able to initiate acro og "headfree" with the two switches on the Devo 7e?
You mean headless mode?
Model menu -> Mixer -> Navigate down to Ch9's "None" and press ent-button -> Change "None" to "Simple" -> Navigate down to Src and when you are on it, press the switch that you want to initiate the headless mode -> Save
I hope Ch9 really is headless because i haven't tested it. Just readed from earlier post in this thread.
06 Nov 2015 11:52 #39649 by DodgeTHIS
While on the subject of customisations, what shall I change in my model ini do get the hold switch to toggle flip mode so 0 is normal flight and 1 + a direction does a flip? Right now it seems to arm the multirotor which is not so useful.
06 Nov 2015 12:05 #39650 by sledgehammer1570
DodgeTHIS wrote: While on the subject of customisations, what shall I change in my model ini do get the hold switch to toggle flip mode so 0 is normal flight and 1 + a direction does a flip? Right now it seems to arm the multirotor which is not so useful.
I haven't done it in .ini file but you can do it via 7e itself by following the steps on my upper post but use Ch6 instead of Ch9. Channel 6 is flip mode. I'm sure its even easier in the .ini file but i have only done changes to the mixer with the devo itself thus far. (noob i am)
08 Nov 2015 22:47 #39758 by DodgeTHIS
I've tried playing around with mixers but nothing seems to make a difference, I did get it flipping but with the wrong switch (fmod) then I could not disable it. Everything I regime the old settings are back and I can never get rid of the binding of arm to hold switch (I presume this is channel 5) on the 7e.
09 Nov 2015 06:47 #39763 by sledgehammer1570
DodgeTHIS wrote: I've tried playing around with mixers but nothing seems to make a difference, I did get it flipping but with the wrong switch (fmod) then I could not disable it. Everything I regime the old settings are back and I can never get rid of the binding of arm to hold switch (I presume this is channel 5) on the 7e.
If you start all over again making a new model for h8 mini, and don't do any changes on mixers and it still binds the quad again of hold switch, it's sounds like a hardware problem on your devo to me. Soldering mistake? Check your wiring, would be my advise. Do you have any other models than h8 mini to test?
17 Nov 2015 13:11 - 17 Nov 2015 13:12 #40149 by eirikso
First of all thank you for making the firmware needed to control the Eachine H8 with the Devo 7e. It works very well. So I tried controlling 7 of them with one Devo:
Last edit: 17 Nov 2015 13:12 by eirikso.
17 Nov 2015 13:43 #40150 by Deal57
Replied by Deal57 on topic Eachine or JJRC H8 mini ?
:lol: :lol: :silly: :lol:
Nice!
17 Nov 2015 16:21 #40152 by bmw111
Replied by bmw111 on topic Eachine or JJRC H8 mini ?
Awesome! Oh, the possibilities....
17 Nov 2015 16:27 #40153 by DodgeTHIS
That is so cool!
18 Nov 2015 10:22 #40181 by dc59
Replied by dc59 on topic Eachine or JJRC H8 mini ?
Very cool man ~~
23 Nov 2015 03:05 #40304 by Richard96816
Replied by Richard96816 on topic Eachine or JJRC H8 mini ?
Yikes!
Let's see them all do that crazy H8 spin in unison. :-)
19 Feb 2016 18:45 #43326 by cyclops13
Replied by cyclops13 on topic Eachine or JJRC H8 mini ?
Requesting a model file for Devo 7E (stock switches) for the H8 mini. I dont have the latest build installed on my devo but have a build which supports bayang protocol. Would I be missing any nice feature for not having the latest?
12 Mar 2016 07:57 #44453 by Maco33
Replied by Maco33 on topic Eachine or JJRC H8 mini ?
Please how do I set the mode flip on physical UP button? It still did not work :-( Flip is 6CH (virtual), switching is shows on dislpay (0-100 -100% or + 100%), but the flip EACHINE still nothing :S Pleas help me.
M.
Time to create page: 0.084 seconds
