LIANSHENG LS114 4CH 2.4GHz RTF UFO Drone SPI DATA
- 92zb
19 Apr 2016 16:21 #46806
by 92zb
Replied by 92zb on topic LIANSHENG LS114 4CH 2.4GHz RTF UFO Drone SPI DATA
Please let me know when you incorporate into the nightly build. Thanks.
- 92zb
20 Apr 2016 12:32 #46862
by 92zb
Hi, by the way, how do you control speed. What I mean is the sensetivity of the Throtle stick, from learner to expert mode.
- goebish
- NRF Weirdo
20 Apr 2016 12:35 #46864
by goebish
Replied by goebish on topic LIANSHENG LS114 4CH 2.4GHz RTF UFO Drone SPI DATA
We don't implement that in Deviation, just use scale rate and expo as required.
- 92zb
20 Apr 2016 22:37 #46904
by 92zb
Hi goebish, great tutorial, thank you very much.
- 92zb
01 May 2016 13:31 #47542
by 92zb
Hi goebish
Version 5 has just been released. Is this LS144 included in this release or I have to wait for a nightly, thanks.
- 92zb
03 May 2016 19:13 #47692
by 92zb
Hi, I was just playing with the above q.copter, I noticed that non of the timers are working. In fact there only two timers, Permenant and Countdown. The Countdown gives error, it buzes continously. Just to let you know. By the way I am still on 4.1 and your test built.
- goebish
- NRF Weirdo
14 May 2016 11:31 #48410
by goebish
- goebish
- NRF Weirdo
14 May 2016 12:56 #48424
by goebish
It's just been merged into trunk, so it should appear in the nightlies soon
- 92zb
14 May 2016 16:43 #48442
by 92zb
GREAT, thanks.
- 92zb
17 May 2016 16:50 #48599
by 92zb
Hi geobish, I am having problem with this copter since it has been incorporated into the nightly.. It drift very severly to down and left, no matter how how much trim you apply. Hope you can have a look at it. Thanks.
- goebish
- NRF Weirdo
17 May 2016 16:55 - 17 May 2016 17:09 #48600
by goebish
The code is exactly the same than in the previous test build.
- Recalibrate Devo sticks then LS114 accelerometer:
www.rcgroups.com/forums/showpost.php?p=30087605&postcount=31
- Go to the trims page then set steps to 1.0 instead of default 0.1
That could also happen because of vibrations (bad props ?) or defective motor (back left).
Last edit: 17 May 2016 17:09 by goebish.
- 92zb
17 May 2016 20:29 #48606
by 92zb
I tried by increasing the trims to 100 with very little effect. I forgot to mention that I tried with the original TX, no problem. I have two of these, one with headless mode. The headless mode one would not fly forward, always flying backword, the other one I managed to fly but it tumbls on its own.
Time to create page: 0.581 seconds
- LIANSHENG LS114 4CH 2.4GHz RTF UFO Drone SPI DATA
