Voice alerts test build
- pulpfiction15
06 Nov 2017 08:41 #65571
by pulpfiction15
@Moeder,
Latest nightly build is working correctly, no issues to report, THANKS.
- yets
10 Nov 2017 01:09 - 11 Nov 2017 03:03 #65681
by yets
Thanks Moeder. I made an external box, speaker isn't very loud but it all works. I get a welcome message but no goodbye message, also get double binding message (I almost exclusively use Bayang protocol). Not really had a chance to explore it all but will point out any bugs for the Devo 7E
Replied by yets on topic Voice alerts test build
Moeder wrote: @pulpfiction15: thanks for your testing experience. Please try the build attached concerning startup message volume on your devo12.
@devo7e-users: Please find attached a devo7e build with voice enabled at the cost of loosing standard mixer GUI. Voice menu is only available in the emulator, which you can also find attached.
Last edit: 11 Nov 2017 03:03 by yets.
- sv650s
12 Nov 2017 19:53 - 12 Nov 2017 21:31 #65767
by sv650s
Replied by sv650s on topic Voice alerts test build
Thanks very much for this great project !
I would like to do this on my Devo 12S, but if i understand well, i can't use the trainer port, i must solder into the radio, that is ok for me, i have already put a 3 in 1 module in my Devo 12S.
But the problem for me is, i don't understand where to solder TX pin of mp3 player on the Devo 12S....
Can you explain me where to solder it into my Devo ?
Can i solder on the GND and TX as on the photo ?
Thank you very much for your help.
Last edit: 12 Nov 2017 21:31 by sv650s.
- magic_marty
13 Nov 2017 00:21 #65776
by magic_marty
The 12s is the easiest devo to perform this mod ..The tx on the picture goes to the rx on the Dfplayer
- sv650s
13 Nov 2017 09:03 - 13 Nov 2017 09:42 #65787
by sv650s
Thank you very much for your answer !
I will try that , but before to do this, with version of deviation I must install on my Devo ?
Actually I've got devo12-v5.0.0-f9f36d5
Must I install the version of "Moeder" devo12-v5.0.0-voice ?
Last edit: 13 Nov 2017 09:42 by sv650s.
- sv650s
13 Nov 2017 13:12 #65789
by sv650s
So i have finally installed the last nightly build because on my 12s, the version of Moelder doesn't work, it's make my devo 12s crazy
With the last nightly build, i have modified all needed files, all works good, i haven't yet test the sound
I have only made the test on a breadboard, and not connect on the devo 12S, and all work well.
So now, i will open my devo 12S to connect the parts to GND and TX
I will give you news when i will made test.
Thanks for your help.
- sv650s
13 Nov 2017 14:25 #65790
by sv650s
Hi again,
All is finished, all seems to work well
There is just a little problem on voices when say time remaining, i think there is not enough time between 2 mp3 files. It's certainly why, the speak seems to be incomplete
- Moeder
13 Nov 2017 14:30 #65791
by Moeder
What language and which mp3 pack are you using? is it just a single mp3 that is bothering? A quick fix is just editing voice.ini and increase the number after the according mp3 file number.
- sv650s
13 Nov 2017 14:45 #65792
by sv650s
I use french language, and i have tried with normal and large package
I don't understand how to increase time... it's on the file name directly ?
- sv650s
13 Nov 2017 14:49 #65793
by sv650s
ok, i see it's just behind "," for increase time
I will try that
thanks
I will try that
thanks
- jejeg
13 Nov 2017 20:44 #65804
by jejeg
Replied by jejeg on topic Voice alerts test build
tu as mis le HP à l'intérieur de la radio ?
- sv650s
13 Nov 2017 21:48 #65807
by sv650s
Pour le moment non, tout est en volant pour les tests.
Je mettrais tout dans la radio ce week end normalement.
For the moment no, all is around the devo 12S during tests.
I will put all in the devo 12s normally this week end
- jejeg
14 Nov 2017 20:29 #65830
by jejeg
ok ,bonne bricole
- sv650s
14 Nov 2017 21:36 #65832
by sv650s
Tu as intégré le HP dans ta radio ? Si oui a quel niveau l'as tu mis ?
- jejeg
14 Nov 2017 22:15 #65833
by jejeg
oui
le N° du post : #62771 (page33)
Le lien vers la vidéo
depuis j'ai modifié quelques annonces avec des répliques cultes (j'ai glissé chef ....) mais pas fait d'autres vidéo
- yets
17 Nov 2017 10:28 #65925
by yets
May I ask whether there'll be more voices and alerts? It's a great feature
- Moeder
17 Nov 2017 11:19 #65931
by Moeder
What specifically are you missing?
- yets
17 Nov 2017 11:34 #65932
by yets
Just specific ones that I like. I'm more than happy to do them myself, if you have enough time to point me in the direction to do that? Alerts like "armed" "disarmed" "Land" "flips" "buzzer". Also a variety of voices would be nice, it's the great thing about Deviation, the customisation
- sv650s
17 Nov 2017 16:56 #65941
by sv650s
Witch freeware / software you use to make voices ?
- Moeder
17 Nov 2017 17:05 #65942
by Moeder
I prefer the builtin command line tool "say" in Mac OS X, as it is handy and produces very nice voice in multiple language.
Checkout the script used to (currently) build the voice packs
Time to create page: 0.283 seconds
Builds
- Voice alerts test build
