Ultimate 7e-256k builds
14 Jun 2016 12:14 #50601 by HappyHarry
Replied by HappyHarry on topic Ultimate 7e-256k builds
that's some amazing detective work guys!
14 Jun 2016 17:25 #50620 by silpstream
Replied by silpstream on topic Ultimate 7e-256k builds
@phantom8, good thinking on the test! I used the same method to test the problem on my tx as I was fixing it.
@dc59, I think it should be sorted now (fingers crossed). Try out deviation-devo7e-256-v5.0.0-0056d17 and let us know how it goes.
14 Jun 2016 22:39 #50628 by dc59
Replied by dc59 on topic Ultimate 7e-256k builds
@silpstream
"deviation-devo7e-256-v5.0.0-0056d17" , excellent ! It works great ! :woohoo:
Thanks for your great job.! :cheer:
15 Jun 2016 01:51 #50642 by phantom8
Replied by phantom8 on topic Ultimate 7e-256k builds
@silpstream, great job! Thanks for the quick fix. :)
15 Jun 2016 09:51 #50655 by Fernandez
Replied by Fernandez on topic Ultimate 7e-256k builds
In my tx I also wired soldered the mcu pins for the pots, but they are not connected. in the ini file I have not set any pots. am I at risk?
I soldered on each of the adc pins 100pf, capcitor to gnd, at least to minimize chnaces lines to pick up RF.
16 Jun 2016 17:31 #50701 by silpstream
Guys, thanks very much for helping to get the kinks out of the u7e. Base on the work we've done, I've sent up a pull request to the main brach with the bug fix. I've also updated the files that are in the test build section. The builds I have are based on BRANCH_5.0 (current release branch), but I've included the bug fixed version of the 2016-06-14 nightly as the PR is pending.
If you are using a u7e, I strongly suggest flashing your TX to one of these new files.
16 Jun 2016 17:33 #50702 by silpstream
Fernandez wrote: In my tx I also wired soldered the mcu pins for the pots, but they are not connected. in the ini file I have not set any pots. am I at risk?
Good idea on adding a filter cap! Any chance you can post a picture of how it is done?
Not sure about the risk even though you have the cap, but I'd still update to the latest files I just uploaded.
16 Jun 2016 17:55 #50704 by HappyHarry
just tested here on stock and 4x3-2x2-2pots and all works as expected, nice work guys 8)
16 Jun 2016 23:37 #50726 by dc59
@silpstream
Tested, all works fine with my U7E , thanks a lot. :lol:
19 Jun 2016 20:10 #50817 by HappyHarry
i've updated the first post with details of the latest build, as SS's pull request isn't merged yet i've also included a build of tonight's nightly with the bugfix code included.
as always if you find any bugs post here or the bugtracker, and enjoy your rc adventures :)
20 Jun 2016 00:13 #50838 by dc59
thanks HH for updating builds. :cheer:
21 Jun 2016 03:50 #50885 by HappyHarry
no worries bud, I know I was a bit tardy this time with the update, i've been working on porting silverxxx's 3d firmware over to the 3d x4 and h8 3d fcb's which took up a lot of my free time, but we're almost there with those :)
27 Jun 2016 06:51 #51108 by Fernandez
Hi guys, I have been running the latest Silpstream switches mod with 3x2 and 6x2 switches and 2 pot on my u7e and been flying a number of packs and it proves to work fine/reliable for me.
I would like to get it merged to latest build and have the Frsky - X protocol included as I can't fly my other drone? Possibly also the AFHDS 2A of Goebish, that worked also fine for me.
27 Jun 2016 08:42 - 27 Jun 2016 08:43 #51110 by HappyHarry
silpstream (yeah i'm good at volunteering other people lol) will have to build that for you atm as I'm currently about 1640miles from my build station, and while I could remote in over my phone it would be tedious and messy ;)
Last edit: 27 Jun 2016 08:43 by HappyHarry.
27 Jun 2016 20:56 #51126 by Fernandez
Haha I missed that one, enjoy your holidays!
28 Jun 2016 04:58 #51133 by silpstream
Consider me volunteered... ;P
Sorry for the wait, I had to send my macbook in for repairs and just got it back. Anyhow I've uploaded new builds for both BRANCH_5.0 and Nightly.
I still need to fix the emulators so, we may need to wait a bit for the PR while I sort that out.
28 Jun 2016 18:18 #51151 by HappyHarry
thanks for volunteering bud ;) :D, and as always thanks for the code that helps take our beloved 7e to the next level!
28 Jun 2016 20:17 #51157 by Fernandez
Thanks guys just loaded the build based on the latest nightly, but without voltage calibrate hardware.ini. and my switches still work, also friky x protocol is back.
I do not know what is the "hardware voltage calibrate" build for 7e and what it addresses, I missed that one?
For the AFHDS Goebish protocol I think is still is in test build state, although it worked perfectly well for me at the time, for now won't use this Rx.
Next step in U7E now will be the voice mod.
29 Jun 2016 17:53 #51181 by silpstream
I've finished with the mods for the emu. I've tested and it works for me. If anyone finds any bug, do let us know. All builds updated in the downloads area.
@Fernandez, the voltage calibration build exposes the values used to for the battery voltage reading. Basically we can measure the battery with a multimeter and compare the readings that the transmitter has. From there we can then tweak the values to hopefully get closer to actual readings. BUT take this with a pinch of salt, our battery ADC readings are somewhat non-linear and PhracturedBlue plotted it to the closest straight line values based on multiple readings as the battery gets drained. You will have to do something similar to improve on that. You could in fact get worse results if it is not done properly. The initial values in the hardware.ini are the default values from PB's calculations.
29 Jun 2016 20:13 #51192 by Fernandez
ah super my volt readout is also slightly off indeed
Time to create page: 0.318 seconds
